reppard
35 mins, thats beastly. my box with 2 xeon dual cores @2ghz was taking 2+ hrs.
Trying to build again *gasp* using make only, so far so good, all cores arent peaking and my memory hasn't shot through the roof.
So she isnt toast?
MMS is not working and reppards patch does nothing for it...
can you ssh into it?seems as though a few real geeks check in on this thread, any ideas on what i could do with a headless powerbook g4?
if you can you can do everything
I run a headless linux home server.
By headless, do you guys mean with out a monitor?
Well here is an overclockable kernel for the optimus m that came with 2.2.1 stock. This allows you to change your cpus speed and has the potential to damage your phone if not used with common sense. That said, I AM NOT RESPONSIBLE IF YOU F UP YOUR PHONE! Every CPU chip is different so stable speeds will vary from phone to phone. My phone isn't stable above 787 MHz. That doesn't mean yours can't go higher
Download the zip to your sdcard.
Reboot into recovery.
Wipe your cache and dalvik cache.
Flash and reboot.
You will need setcpu or a similar program to change frequencies. I have to configure the gbrom so the cmod7 settings will have that ability. Hit the thanks button if this helps and the donate link if it really really helps![]()
Big thanks to asadullah for organizing our mob on LG and making the source code possible!
Enjoy!
UPDATE:
This version works with any rom and wifi modules were compiled separately so wifi works right out of the box.
Lower set CPU Max Version, people with boot loops test this update
Max set to 729600(i can go lower if needed) and default governor is ondemand.
r.O.C.K-v0.3-AnyROM.zip
MD5 Sum: e5e905eb5fcd6a9e93a180c7e25c2b3d
In compliance with GPL, here is the source:
r.O.C.K-v0.3-Source
Battery Calibration install this and let your battery fully charge. The run the app, unplug the charger and calibrate. This should be done after flashing a new rom or kernel.
thanx for the links, but unfortunately it says page not found when i click on it![]()
yeah, idk why it did not work m on this thread. but its ok. i found itthanks for your help tho. im gonna flash this right now and see how it works out.
everything is in good WORKING condition... any way of changing the "roaming indicator off" thingy? lol
I got mms working with no patch required. Gotta get rid of the roaming indicator and I will post an alpha build.
There is going to be three builds all stemming from IHO this is getting a bit ridiculous.
I agree that 3 post of essentially the same rom is alittle "overkill". I didn't really see the point in the one released after bobz's build as it was the same thing with less stuff working. I would like to release on the basis of improvement but I guess I don't have to release it. Could just use my own build personally. I guess no one will be interested when I finally get the screen animations and in rom clock speed changing working.
I never said I wouldn't be interested. I'm very interested in fact (see my post a couple back where I said yay). Please keep to fix the bugs.
Haha no worries man. I will still be working on fixes. I've been learning and debugging stuff since o got this phone. I was just taking an immature stab of sarcasm at the previous post. I will post whatever improvements that I make. If it annoys him he doesn't have to use the rom or even read the thread. I seem to remember there being about 4 or 5 roms based off of stock but no one complained about that.
