Root Unofficial CM7 port, inquire within.
Hey reppard have you looked at mine and bobs repos for possible fixes for your issues? And do you have a repo?
Well I forked bobs and the IHO repo to mine. I am still really new to repos and git hub, I've always worked on a local level so once I get everything working I will start updating a my repo. I have pretty much everything working besides the screen animations and the cpu settings in cm7 settings. Also the wake up/lock screen lag is an issue...I think most of these issues could be kernel tweeks.
I think the screen issues are CM related, I had the issues on the stock kernel too.
With playfulgods iho the lockscreen is much faster
L53Aa2B
My methods may be crude ...but they work :). This was just a test build I did on the way out before work. Gotta clean up the clock frequencies and add a few. First build is almost done. Fixed mms out of the box. Fixed the dumb banner too.
I use ADW from the CM src over Bob's preference for LP. The screen issue seem not as bad with ADW. Disabling screen on/off animations and surface dithering help it out too.
I took your suggestion and down loaded ADW as well. It does seem to make it a bit quicker.
L53Aa2B
keep up the good work!:D
L53Aa2B
When Is this gonna be available ? ;)
