Root Unroot HELP NOT WORKING :(
And it is not in your app drawer?
Hind sight, do you have the market (the old play store name)?
What happens when you long press on any home screen, and choose to add an app on the screen?
So the first time I installed the rom and then gapps and it didnt work. Second I rebootes inro recovery wipe everything reinstalled rom set up gmail then the app said no longer installed ran the apk and now it seems to be working just fine.
Nice then :) I wonder if it had something to do with trying to flash gapps on the first rom flash but......all is good now?
That could be why and only thing am I always goibg to have to run the apk to use the play store cuz that message POP up again saying it was no longer on the system
Once installed, it should stay installed...no need to reinstall the apk.
Right now is it, or is it not in your applications drawer?:confused:
It's working didn't know it made a new app lol
yeah its weird how it works like that with mikg3.11. i just wanted to say congrats on flashing a new rom!!!!!!!!!!!!
hope everything works now. if not please let us know and we can help troubleshoot.
if you want to try out new roms go here: http://androidforums.com/evo-4g-all-things-root/618281-list-utilities-apps-roms-kernels-og-evo.html. there is a staff pick section that has some great suggestions of roms to try out. notice that cm7.2 is not one of the staff picks?
Ya i think I will stay with the sence roms for now till I decide on the GA3 or the note 2. Question what is some advice on overclocking and is there anything to increase battery life
yes, you can try kernels
here is a guide for you:
http://androidforums.com/evo-4g-all-things-root/389360-kernels-dummies.html
and use rom tool box to control the kernel
you can get most kernels from here:
Also would I be able to Flash RA since I did away with the clockworkmod app on this rom? Can i flash RA thur Rom toolbox?
no there are different ways to flash amon ra. the guide i linked you to earlier will show you how to switch recoveries.
Do I have to have s-off to install kernals
for the og evo, having an unlocked bootloader and root permission (via superuser which you can flash by itself or flash a rom), you can do anything an s-off phone can do. i would not have mentioned it if this were not the case. so do not worry if you have s-on still.
you guys are lucky. other phones like the evo lte even though you have the phone unlocked you have to fastboot command the boot.img which is where the kernel is at separately from flashing the rom. way more of a pain to do.
