How do i install from Android 2.1? I have never installed custom rom and what i have is rooted stock firmware.
When is the camera going to be fixed?
And is there a possibility of bricking my phone?
hows the beta 5 coming?
does anyone know how to install beta4 through fastboot? my phone seems not detecting sd card...
any suggestion on how to make my phone detecting the sd card again? alrdy try various method from this forum but none of them succeed.
my phone not detecting the sd card since Sept last year..
One day by chance, my phone detected the sd card then I flash the ICS 4.0 by mike and this solved the problem(I use ICS for several day without any problem regarding SD card) and then I switch back to ASIS.
Today the phone not detecting the SD card again =.=
right now I'm using kingston 8GB class 4, so what class would you recommend?
Well then,I will wait my phone to detect the SD card by chances(hopefully soon) and flash ICS![]()
One final question,
to avoid boot looping, I have to wipe cache partition or wipe dalvik cache?
*btw why my signatures not appearing?
Flash player support!!!![]()
Quick question about Screen calibration.Does it work?
Problem. I tried to install 4.0 but now the phone wont work
I installed it trough recovery and at first it went all ok.When i tried to turn it on, the LG screen came on,ok.then the shards came flying,at first it was a bit slow.Then after a minute or so, it stops completely,wth should i do now?
