I am having android 2.3 ,recently i bricked my phone but it was recovered by some method .day before yesterday i was playing game and after playing game i kept it in lock mode.after some time when i switch on the phone from lock mode it get restarted by own i thought that i might have put the finger on switch of button .during restarting it got struck on the boot animation .so i had to recover it through my starting recovery.now phone cant receive/send any thing from Bluetooth and my phone get restarted sometimes when in lock mode/playing games.I had also tried to set my max frequency to 729 MHz but still same problem .so anyone help me if these problems will be solved when i will switch to ICS,Also tell me that if keyboard and camera problems are solved in beta 5
See PM, it could be the brick has damaged alot but what is in the PM is all I can think of now.
Yep Beta 5 out. Download right now!
Changelog:
Changelog for beta 5:
-All the CM updates like overclocking in settings
-Genlock, overlay, libqcomui, titlerender to make rom liquid smooth
-KGSL 3.0 in kernel is supported(the gpu driver from 3.0 kernel)
-Camera works now but it has no preview and recording support(luck of codecs, to be fixed in next ver)
-Wifi shows signal and turns on without any problems(new supplicant)
-The timezone fix is inside for not working sim cards
-System is around 180mb with gapps inside
-You can watch youtube with lags instead(omxcore is inside,now fighting with hardware render)
-The native storage is avabible but doesn
Hi everyone first post
i downloaded the ice cream sandwich for lg gt540 and for the most part its great just one or two issues with battery life and the other is with youtube not really working properly kinda laggy but the sound is fine. Any ideas would be great for a fix.
Id like to thank anybody in advance.
Thanks
only problem i have trying this out, is that Recovery mode isn't coming up/working for me.
is there an alternative?
trying to upgrade from SwiftDroid v2.0 ASIS
Do you have recovery installed? If you still have the ASIS files on your PC connect through fastboot and find your recovery.img (i like to move it to the same location as fastboot) then type in cmd.
cd {location of fastboot.exe}
fastboot.exe flash recovery recovery.img
Then reboot and hold the home button when you power on and it should boot into CMW recovery.
just flashed the recovery, but im still getting a blank screen. =/
Just installed the Polish Blood preRC only issue ive found upto now is the market wont load, it flashes up then switches off immaculately, tried a new apk file but not getting any joy, can i have a nudge in the right direction
By the way, Polish Blood preRC is out for anyone that doesn't check xda, mikes blog or mikes twitter, link is here Deposit Files
Changelog is:
-Test the BT headset, I made some changes that could fix that
Again all credits go to mikegapinkski of XDA.
I turned the phone off to recovery mode and installed it using the zip off the sd card , it takes a few mins but it does install then reboot, let it finish. then give it 10mins then switch off and back on again and its done. Back up your numbers before you install as they dont work correctly.
How did you install it ,i have tried installing via zip but it got struck at coloured lg logo.can you send me a backup of polish blood RC .please upload to media fire not deposits file.I will Be thankful to you
