Phantogenic
So if we already have cm7 installed how do we update cos I could do with better battery power
SwiftDroid v2.0 M5 Fixed
http://swift.kulkoff.com/SwiftDroid_v2.0_recovery_M5.zip http://swift.kulkoff.com/SwiftDroid_v2.0_fastboot_M5.zip
Source: Mur4ik's Twitter
will this version not abort when i install it via recovery??
I haven't tried yet... According to others it gives an error but installs...[
did you try it now?
Hi..i am planning to upgrade my gt540 to newest version..i have couple of questions:
what the latest one i can get??i heard bout 2.3.2 and 2.3.3
And also,wil i be still able to download games and apps on market??
thank you
hey dudeman, i managed to install M5 via fastboot and everything's fine but i have a question though..what's the difference from v1.9 and other cyanogen versions?? everythings pretty much the same to me, or so i think...could you enumerate some significant features added to this version(milestone) that is not on cm v1.9?
Try putting the phone in emergency mode by holding the vol down button and powering on the phone. 'Emergency Mode' will be displayed on the screen. Then change the 'PhoneMod' in KDZ flasher to 'CS_EMERGENCY' and the other to 3GQCT. Then try flashing.
It's not working: by keeping pressed vol down while powering the phone I enter 'Download Mode' (is that Emergency Mode too?) yes. After that I connect the phone via USB to my computer but the phone does not appear as a new drive. Installing the drivers causes the phone to be recognized sometimes, but the installation ends with a message stating that an error has occurred and the device might not work properly. Sometimes it only says 'LG Android USB Modem correctly installed'.
Either case, if I then execute KDZ_FW_UPD.exe, using CS_Emergency phonemode and 3GQCT type, it ends with a 'Phone not found!' error message.
sign into your gmail account and the market will appear for you.hey dudeman, i noticed theres no market and youtube...how do i install them?
agreeddude why not make an thread for the new update ????
i didnt even know it was on here
anyways i had trouble updating it and because of that i could master the ways of fastboot lolllll thanks for your tutorial dudeman im still hoping for the bluetooth device to work and i hope im not the only one wanting that
Are you running Win7? Try disabling the usb modem in device manager and try again.
Guys i am having a problem. Sometimes (more often than not...) when i am in an app and hit the home key the launcher app crashes or at least rerdraws the widgets and the phone is unresponsive for a few seconds. This is extremely annoying and i didnt have this problem with 1.4b. I ve tried the Go launcher that comes with the mod and also zeam launcher. It doesnt seem to make any difference. Also it seems like the home selector doesnt work. It changes the homescreen app but after i hit the home key it reverts to the one i have set to default. Any ideas ? (yes i checked the system persistent checkbox in the Go settings)
Nope, XP. And weirdly enough, the USB driver doesn't even appear now. I will try reinstalling the drivers one more time.
[edit] No dice.![]()
There should be XP drivers in the first post, did you try those?
