Root [UPDATED 8/8/12]Breath of fresh air....an update
does anyone have any backup problems. yesterday i flashed cm9 then when i tried to restore to my backup it says cannot restore my system. it gives me an error when it restores my system.
You're not using dedupe in recovery are you? I tried that at first and my restore failed. If you can't get it to restore, the easiest solution is probably to have someone shoot you a /system tarball and restore it manually from recovery. Either way, talk to PG, he's the recovery guru.
im on the cwm 6
its weird cus i can go back to the stock v6 rooted nandroid
is a fresh backup or one you used before?
*Home Button is not responsive (How would on screen buttons react?)
*Live wallpapers have slow load up time
*Sdcard does not mount
*No lockscreen?
*No Camera
*System UI slow response?
*Wallpapers not loading up? (No previews)
*tribuchet has slow response (How would default launcher work?)
*GPS working?
Il see what I can do on my end
  • Like
Reactions: tdm
*No lockscreen?
*No Camera
*GPS working?
Lockscreen and home button works, you just need to install gapps
  • Like
Reactions: tdm
*No lockscreen?
*No Camera
*GPS working?
Lock screen works reboot the phone... Home button works the launcher acts dumb with it... Just install a new one. I believe hardware acceleration isn't kicking in... I could be wrong...
The pmem driver is not functional, I think this is due to a kernel/user header mismatch. I fixed the headers today, hopefully it will work for the next build.
Makes sense.... I ported something and seemed a bit faster than your build but not by much... There's not much to go to be honest.... I can't believe we are making progress this fast the speedy took about 6 months to have stable ics and we still don't have 4G working lol.. I'm glad we have you, but D2A, Phillips, Micheal, PlayfulGod and many more devs! I yall are why 50% of spectrum users have lost their mind lol :-)
  • Like
Reactions: tdm
Oh, and just so everyone knows the plan... Well my plan anyway...
As soon as the radio is functional, with or without cameras, I'm going to make an alpha release, then do an aokp alpha. Next I'm going to do jb, cuz that's what is current and the devs are working on.
Sounds awesome. I really appreciate all the work you've done.
  • Like
Reactions: tdm
... and you'll be my hero. :D
srsly, I feel like I need to donate to you or buy you a beer.
BTW, have you tried using the Plague or Blitzkrieg kernel with cm9? Just a thought... if they work with cm9, it would likely make integrating radio and other functions, since we have both working with our current libs & rils.
  • Like
Reactions: tdm
Are they ics kernels? Not going back to a gb kernel. But I would take a peek to see if there's any code changes to be applied for the radios.
nah, they're gb kernels.
I'm getting an assert error and when I turn off assert verification in cwm, I still get the error. Any suggestions?
