tdm
Android Expert
New build: quattrimus-VS920-cm9-test3.zip
md5=e296103d8885c841cf4734e2102bc57f
The radio/ril still does not work. GPS depends on the radio so it doesn't work either. Most everything else does.
Visible changes:
* PG's lights fix.
* Cameras work.
* Added bacon.
Under the hood:
* Switched product name to i_vzw for cameras.
* Reworked init scripts to match ics leak.
* Added a handful of proprietary services from ics leak.
Areas for devs to investigate:
/system/bin/qcks is segfaulting at startup. What is this and how does its failure impact operation?
/system/bin/qmiproxy is segfaulting. This is probably a ril/radio related service. It may be part of why the radio doesn't work.
/system/bin/ATFWD-daemon is trying to start a service called AtCmdFwd. This is apparently a proprietary service in the vendor's framework:
This may be a part of why the radio doesn't work. "AtCmd" may refer to the radio/modem commands, eg. "AT command" (Hayes modem command set). The modem used in MSM devices doesn't use AT commands, but other devices do (like the OMAP3 based Marquee). Can anyone decompile com.android.internal.atfwd.* so it can be reconstructed and added to the build? That would be a huge help!
Visible changes:
* PG's lights fix.
* Cameras work.
* Added bacon.
Under the hood:
Code:
$ strings framework/services.odex | grep AtCmdFwd
AtCmdFwd
AtCmdFwd Service
,Lcom/android/internal/atfwd/AtCmdFwdService;
starting AtCmdFwd Service
$ strings framework/framework2.odex | grep AtCmdFwd
AtCmdFwdService
AtCmdFwdService.java
IAtCmdFwd.java
1Lcom/android/internal/atfwd/IAtCmdFwd$Stub$Proxy;
+Lcom/android/internal/atfwd/IAtCmdFwd$Stub;
&Lcom/android/internal/atfwd/IAtCmdFwd;
$com.android.internal.atfwd.IAtCmdFwd
