If you have a custom recovery you can just click install now and the OTA will fail at the custom recovery screen.
The only concern I have are about rumors Verizon is collecting MEDI's of users who reject OTA updates as a method to flag people who may be rooted or running an unauthorized ROM's for further scrutiny. Thoughts on this anyone?
so.. would it be save to say then, that i could un-root download the update and then re-root?
Couple of points:
2. I would also wait until someone figures out whether or not the update can be rooted before you take it. I did not see anything earth shattering in the update which would make me want to give up root.
DZ
This may be true but the notification is extremely annoying. Are Velocity 1.1 users getting this notice? Perhaps I'll finally get around to installing that and enjoying my Ally for what it can be.
I got the "update ready" notification overnight and I could not get it to go away, so I pretended like I was going to go through with it. I clicked the restart and install button and it hung trying to reboot. I rebooted by holding power then choosing reboot. The phone came back up normally without the notification thus far, I also have no updates available when I click the system update button inside of "about phone". I am hoping the notification does not come back.
Oh yeah, Velocity 1.1 with GNM's Amon Ra 2.2.1 recovery.
It will not come back
The reason it failed to install as you described above is because of the custom recovery. Since it failed the notification will not come back, just as previous ota's
I'm running Velocity 1.1 & I tried to accept it, it didn't take, & hasn't came back....that was last week. as far as the update itself it's ABSOLUTELY useless if you're running Velocity 1.1 bkuz the MINOR fixes that the update has ARE included in Velocity 1.1 as stated in other threadsThis is not true. I 'went through" with the update a couple of days ago. I woke up this morning and the notification is back.
I realize that. I'm on velocity 1.1 I was just stating that I "went through" with the vze update to get the notification to go away. It didn't take as expected and the notification went away for several days but it has now come back.
So after reading this thread (I had the same question as the OP almost word for word), the conclusion for now is to wait for a Velocity update that will take care of or get rid of the recurring prompt for the update. Is that correct?
By the way I believe I'm using Velocity 1.0 script v31. (Says 1.0 in the settings anyway.) Should I install 1.1?
