UBRocked
VZW Nexus Please!!!
UBR,
Sorry, I missed seeing the above before...
Are you speaking of CWM not supporting adb access just while you're using a JB ROM or at all times?
(I've never had a problem with any of the custom recoveries (any device) not supporting adb).
I'm not even sure it could ever be a ROM-related issue because the kernel that a custom recovery uses is packed into the .img.
Lemme know--I'm curious about this.
Thanks!
I was on ICS but couldn't boot past the boot animation. I could get into the bootloader and recovery. I wanted to be able to use ADB to pull the data off of the internal storage and this could not be done with CWM. From what I remember...ADB should work from within CWM but I could not get my computer to recognize the phone was mounted. When I installed the other recovery...it worked just fine and I did an ADB pull for the entire SD card without issue.
This is why you shouldn't make phones without external SD card slots. Why we are moving away from this is baffling to me.
its a shame but it was. Im glad you didnt have many issues cause i know i sure did
