I think the longest I've stuck with a single rom is about a couple months running Liquid on my X, and I always have to push my OC to the limit! That's the whole reason I bought this sweet phone!
I understand people like to tinker and push their phones to the limit. That being said, other than those reasons I see absolutely no need to OC this phone. It's fast as hell as is and anything more than 1.2 is just a waste of battery, IMO.
With the Galaxy Nexus running a cpu designed to run at 1.5Ghz, why do all the overclock kernals stop at 1.35 or 1.4Ghz? Shouldn't it be easy to get this thing to run well over 1.5Ghz?
i say give it more time. I predict we'll see at least 1.5 if not 1.7 within 6 months. Heat is apparently a big factor for the G Nex. I've read reports of a Dev putting his G Nex in the freezer when it was OC'd really high just to keep it cool to see what he could get benchmark wise.
I doubt you will ever see any stable overclocks higher than 1.4. TI intended for the 4460 to run at 1.5 but found that in its current form it just was not stable so backed the clocks down to a 100% stable speed. It is incorrect to think that the 4460 is "underclocked" as its running at the highest speed TI could reliably maintain. You may see 1.5 4460 devices in the future but only if TI can figure out the issues keeping it from reaching that speed.
Nobody is reading the "why" part, only making assumptions here. Interesting.
Yeah you are right. Currently it wont happen but I do have faith that some dev will be determined enough to find a way. Having said that I still don't see a need to OC the nexus at this time.
From the link you posted if the problem is the DCC crashing when turned off to scale down the speed it is a software issue and can be fixed by the dev community not a limitation of the hardware causing the limits on OC.
Let's hope that the multiplier mod can be modded, otherwise I'm not holding my breath. You should be thankful for the undervolting mods so far. The built in and distributed TI code, is that GPL? I haven't gone that far, but if there's source out there, I'll compile it for arm and give it some goes... even DCC mods if the source is really there.
Again, this is a cursory look. Not going to get serious into the code until we get official OTA 4.0.3
You apparently know much more about the development than myself. I've watched many thing that "can't" be done with Android become things that can be done so I put my trust in the dev community.
Really with myself and OC it will come down to does my phone need to go faster, if so it would be great to be able to push it to where it needs to be, if not then what is available beyond what I need is great but nothing for me to fret about.
i will admit that i have an addiction to speed. as with every car i have ever owned, there comes a point where a device certainly doesn't NEED to be any faster... but i still WANT it to be.![]()
Well, let's hope that engineers like myself can help and/or consult, lol.
Most people will be happy with undervolting for battery life. OC on this phone will super-kill your battery.
Most phones suffer poor battery life when overclocking, or more battery drain, that's a fact. I've overclocked a lot of phones, even with the low governor at the factory setting. Just give it time, I've presented the hardware challenges... there could be a way around it.
However not understanding the hardware... you are all just wishing, and TI isn't listening.
