Having a weird issue. I changed my softkeys so Recents popup when you hold Home. But it's not popping up.
Anyone else have the issue?
I'm a beginner to rooting and came across this ROM. I have it flashed, but I can't seem to figure out how to get Google Apps going.
The instructions say flash gapps as soon as the ROM is applied but I dont know how to do that. Can anyone assist? I dont have a GMail option to sign in with under Accounts and the only way I even have an option for the Market is via Nova Launcher, but that won't open either.
Thanks..
You download the GApps package listed, and flash it the same way you flashed the ROM in recovery. What is it you're unclear on?
I didn't know where to find the Google apps file to flash with, guess I could have been clearer.. but I finally found it and it seems to be working.
Quick question. Can I use the Leaked 4.0.4 OTA update and then flash the rom? Or am I needing to flash 4.0.3?
The 4.0.4 is a stock 4.0.4 ROM, therefore flashing AOKP, a separate ROM, over it will completely revert it. AOKP can't/won't be 4.0.4 till it's opensourced. Simple answer is no, but you don't have to flash 4.0.3 first it will do it by itself. Just flash the ROM
Ahh ok so I can just flash from 4.0.2 then? If I'm understanding this correctly
So I only need to clear the dalvik cache to go from 23 to 25?
Correct with a full system/data wipe of course
Stock launcher? Nova?
Do they randomly disappear, only after a reboot, etc..?
What mods are you running if any?
Unknown. Dirty flashing 2 ROMs ahead might be pushing it
Odd and random. Is it still happening? Nova could be the culprit have you by chance done a Nova restore? Uninstall and reinstall Nova? Try those first. If still borked, you could always do the "pita" thing and start freshThis is with the stock launcher and the behavior is random. I have Lean Kernel 2.2 and a boot up animation. That's it.
Roman said if coming from 23 or 24, a dirty wipe should be just fine when upgrading to 25. Go for it!Well I'm going to do it from 23 to 24 then 24 to 25
