[Verizon] [ROM] AOKP JB-MR1 Milestone 2 [4.2.2] (07.21.13) TORO
Nice to see that is out. Don't have time for a full wipe tonight. So will probably dirty flash. But of course I am on Gsm version now. :p
Apollo music player is now gone, the nav bar icons can no longer be changed (rom control force closes), and they still don't have lockscreen targets? :eek:
Hey there Pits,
I went ahead and merged your thread into the ROM thread. Keeps visibility of issues in one place and cleans up the Forum a bit. Thanks for your understanding in advance.
jmar
I dirty flashed from build 2 and have no problem changing nav bar icons - color, quantity, long press task, transparency... I could change everything without problems.
I don't know what apallo player is so no problem their either.
I would really like for the devs to bring back the torch when long pressing power button. I used that a lot.
I don't have Apollo Music either which is fine, since I never used it anyway.
AOKP needs moar features though.
I have no problem changing nav bar icons -
Could you try setting up a nav button to open "Settings" (Not menu) and see if you can change the icon?
Here is mine. I cannot change it. When I try Rom Control stops working.
I went ahead and flashed version 3. Runs great so far! Still miss some of the old ICS AOKP customization, but they are getting closer. I also have the issue with changing any of the nav-bar icons. I get the force close. Not a deal breaker by any stretch of the imagination.
ROM runs BUTTERY SMOOTH! =)
Tried but not sure how to select just settings. When I press "button 5 action and icon", it brings up a list of options but none are just settings. There is an option for "custom app"and you can select a "settings shortcut" that takes you into settings and allows you to choose a particular setting. Is that what you mean?
At the top of the list choose Applications and scroll down to Settings. Choose it and see the icon it places. Then try and change it.
I went to XenonHD and it works. Tried it in others and it fails. Lemme know.
Yup...worked fine for me. Might leave that there too...
I added it, changed it to something else, re-added it and everything worked flawlessly.
I am excited for Build 4!
Hoping for DRM fixes for Google Play Movies/Hulu and general Swag enhancements. I have tried every ROM out there, but I feel so comfy here. :)
