gapi
Android Expert
B4 is working fantastic on mine with LeanKernel. I have none of the above issues.
It did not go without incident though. I flashed and found I could not assign custom icons to nav bar buttons.
The culprit was me restoring apps with TBU backups made in ICS.
I re-wiped-flashed and let Google Play restore my apps and its all good.
Copied the ICS TBU backup files to a safe place and did a full delete of TBU backups and re-did the JB config TBU.
Also, I have tried several inverted GAPPS packages and it seems at least one apk out of each package fails. So......... I did them all one at a time until they all work and have them packaged here.
You can flash them all in a single session and boot.
