colchiro
Extreme Android User
I just had a reboot too. 5.1 with maxiumus apps and no mods.
4 long calls today and 3 reboots during those calls.
Thanks SecondShot - I'll have to try that! I just went back to soft keys... I'll get on this
EDIT: For the benefit of our readers ( and me), can you please explain "LMT" and where to find it? It's certainly not in the Pie Controls section...
My network (both radio and Wifi) is a bit spotty, as in it goes grey. Usually an airplane toggle will fix it, but didn't know if others are having the same issue.
Stock kernel that comes with ROM.
Touch to wake...removed from this kernel as it causes issues also...so if changing kernels with ti it will cause problems. there really isnt anything in the rom to change to make touch to wake work better that i have seen. all i know is we tried it and it causes major problem if the kernel supports it and its turned on in trickster.
1)
2)twrp--we have had people using twrp having reboot issues, systemui fc, bad gpd, wif problem. they returned (this is 5 people thus far) installed cwm wiped clean installed and all went away. do not know what is going on with twrp but this is 5 people that im aware of not part of team sourcery that did this and the problems went away.
3)titanium doesnt matter if you only restored data apps it causes problems.
also alot of people like to say i only restored data apps but also restored wifi and/or bluetooth settings this is in the settings app that is a system app and it causes problems.
6)clean install using cwm phone to wifi as i canceled my tmobile accont since the move edge only here. so its been on wifi. uptime 109:56:08 last reboot was testing a mod. notice on wifi also.
7) also hearing some compatibililty problems with the new radios out there i never upgraded to them and have no reboots or issues on the vzw phone. gps locks instantly.
ok so to sum it up. if your having problems ditch twrp and install with cwm..im sorry i know i hear twrp has some awesome features but it appears actually wiping isnt one of them.
NEW Radios --revert
We try to recreate every bug reported and following what is stated above these are not reproducible when installing after wiping with cwm, intalling the stock supported gapps. and not using titanum or any other restoring backup app.
as stated im running one phone on wifi 1 on vzw netwrok (old radios) and have no connection issues on either.
Thanks for using sourcery and hope some of this helps.
you can always delete your gmail app and reboot... then download from the marketLooks like there was a fairly big Gmail update that includes some new notification actions. I know that updates & inverted apps are at odds with each other, but does anyone have any thoughts on how long that might take? Just curious when I should definitely check back for an updated gapps package.
Ok, I been reading up thethread,. Am I correct that twrp is why this ROM was acting bad with there boots, dropped data & WiFi? and going back to cwm will eradicate these problems?
we have had testers report a vast improvement.
If I switch back to cwm will I lose my backups I have now?
