With the zebra Gapps does anyone else notice that executing the search function closes the app?
You have to boot ROM first, then go back in recovery and flash zebra to get voice (Google Now) to work properly (per Damien).Am I supposed to flash zebra gapps just like any other gapps file?
Dirty flash doesn't fix either. So I just installed the Searchbox apk from bboy or Trav624 (don't remember which), and all was well.
Am I missing inverted Pandora somewhere?
OK so thanks for pointing me in the right direction. I can't get it installed though. I'm also having the Google search issue but not just voice search. It's force closing if I type something in and click search.
My phone rarely gets below 30% and my phone had been idle and untouched for hours. One of these times it had been on the charger for a couple hours and the other was a 3 or 4 hours after coming off the charger.![]()
what about the search box apk? Does anyone have a link?
If you are using ES explorer go to settings and go to root settings and check everythingIs there some permission setting I need to change first? It won't let me paste it.
Thanks worked perfectlyhttp://b-boytm.webnode.com/themed-apps/faqcbm_601809/10/
Bboy's site with all his inverted apps, including Now.
