What are you using Chief?
Root Explorer. It's a paid app but I wouldn't want to use anything else.
root explorer works well
Why, yes it does
If you are using ES explorer go to settings and go to root settings and check everything
Weird parsing errors with black Pandora and Bboys black gapps.
You don't have to use zebra gapps with 5.1.6. I've cobbled together a mix and match gapps package I'm very happy with and it works on all versions of Sourcery. Trav624 has a gapps package that works and if you don't care about inverted, use the latest from goo.im. I believe the older Sourcery maximus/minimus will work too. Until zebra is fixed, they don't dirty flash successfully and some problems have been reported while others have no problems.
I'm just saying, don't let the gapps keep you from the best version of Sourcery to date!
Is your voice search working with your gapps? I will try Maximus when my battery charges back up.
I used 5.1.6 and the nophotosphere Gapps and everything works splendidly. This "experimental" will most assuredly tide me over until the next full release![]()
So what is the reason for Gapps without photosphere? Does everyone just hate it or what? Is the ROM camera better or something? I guess I missed that whole conversation about why we should like non-photosphere Gapps.
