I re downloaded it from tools and it worked, bad download lol thanks for your helpWell, it might be a bad download: did you check the MD5?
BTW, 5.1.8 is in the Experimental section of Sourcery Tools![]()
I'm still on 5.1.5, but I encountered the "toggles not working issue." This is after wiping properly, default kernel, etc. Plus it only seems to happen after using the ROM bug-free for a week or two.
But a curious note: I don't think it's the toggle that isn't working, but the actual switch. I went to Mobile Networks to manually switch 4G to 3G, but it wouldn't switch.
Just FYI if it helps with bug testing.
Okay folks:
Anyone else having a problem connecting to wifi with 5.1.8? Every time it tries to connect on my Verizon Nexus, it hot reboots. When it comes back up, it says "The Galaxy Nexus Settings has stopped working". But I had wifi turned on, which meant it kept trying to connect and kept rebooting! It took some fast fingerwork to turn off wifi before it rebooted again...
Okay folks:
Okay folks:
Okay folks:
Sounds like a phone or router issue.I'm not on 5.1.8 (I'm no 5.1.6) but I have had this issue with earlier versions...at least 2 of them. One of them was 5.1.5. IIRC, I believe I had this issue with XenonHD as well.
Excellent news! I shall update today.several toggles were quirky previously that is why they have been all redone. this happend post 5.1.5
Just got 5.1.8 set up. Amazing the number of improvements between these versions. Didn't expect such a difference from 5.1.5 to 5.1.8.
this be true. while this is another exclusive rom feature. it is for portrait only.
we can look into doing the black for landscape also. but not all other images they jsut look to funky.
