viper, have you seen it on any other rom? if so. link me...not sure exactly what your looking for
The last version of Sourcery was Sourceress and it had its own Gapps. The newest development, Believe, comes with brand new Gapps. Look in Settings -->Sourcery Tools --> ROM Updates.
EDIT: Anyone know how to get to Developer Options in the Believe ROM settings?![]()
Chief, Go to Settings --> About phone and keep clicking on the build number until it says that you're a developer.The last version of Sourcery was Sourceress and it had its own Gapps. The newest development, Believe, comes with brand new Gapps. Look in Settings -->Sourcery Tools --> ROM Updates.
Chief - don't know if it'll work on 4.3 but in 4.2 it was hidden and the following worked to find it -
Settings > About Phone - tap on Build Number 7 times and it should appear. At least it did for 4.2. I did it on my daughter's phone and it worked so it can't hurt to try it on Believe.
You can download Slim Gapps from slimroms.net, they're under add-ons in the download section.. I've been using cajunflavoredbob's Midnight Gapps Project aroma with no problems.Thanks to the devs for keeping this alive
I wanted to update to the final version of sourcery and the push notification said to use whatever gapps we wanted but recommended a slim form...?? Anyone have a link to the latest recommended gapps they've used? Slim version??
question: does anyone know what would cause statusbar and nav bar to disappear and a reboot? im running the end rom...
I'm running Sorceress and my phone did that last week. In Recovery I fixed permissions and cleared dalvik/cache an it's been running smoothly ever since.question: does anyone know what would cause statusbar and nav bar to disappear and a reboot? im running the end rom...
I'm using the newest TWRP...think it's under the advanced button?what recovery are you using that you can fix permissions while in recovery?
I switched from cwm to twrp a couple months ago. It seems to work better on my gnex for some reason and the touchscreen options are great.ohhhhhh, well im running cwm and that option is not there...
