Two bugs to report. Running 2.1, Justinbean 8-20 gapps, Copper glass weather icons, dirty flash over clean install of 2.0. Kiwi Cobalt theme
1. Lockscreen options aren't sticking. I set the wall paper, choose 8 targets, and set the targets with custom icons from the gallery.
All this works for a bit, then things start to fall apart. It seems #8 disappears first, and it's really gone -- sliding over the blank space doesn't open the programmed app.
Then either the lockscreen wallpaper disappears so I just see the desktop, or the custom icons revert to the stock ones. Or the icons revert and the wallpaper disappears -- I haven't quite noticed which order it goes in.
Reprogramming it all sometimes works, sometimes a reboot is required first. But it always crops up again after the screen cycles on and off a few times.
2. The weather icons are off by 12 hours (Copper glass weather icons again). All day I was looking at the moon, and now that it's night, I'm looking at the sun.
Minor irritations -- everything else is rock solid!
) so if you have another one to try feel free to provide it.
