I've decided to take on a weekend project and finally leave my stock build. I got about 20% through this thread, but it would've taken a while to finish. So some of these may have been answered already.
1. I was reading about the built-in torch (flashlight) function. I've been using TeslaLED plus Widget locker so that I have a toggle in my unlock slider on the lock screen that toggles it on and off. Unfortunately, there's a 3 - 5 second delay on the GNex. Is there anything built in to the ROM that could accomplish this? I'd really rather get away from Widget Locker, any way because there's some lag sometimes with it.
2. When installing the gapps package, do these then get updated in the Play store when there are updates, or do you have to flash a new package once someone creates it? If you do have to reflash, do you have to set up your data or accounts again? Does the gapps include Maps, or is that separate and available through the Play store? And most importantly, is Navigation reliable?
3. Was there any consensus made on the best kernel?
4. I have Google Voice set up for my VM. I didn't use the built in software method because it didn't work. I used the method where you dial the phone number that sets it up to forward or whatever. I shouldn't have to redo this after flashing the ROM, right? And I'll be able to access my VM's from the dialer like I can in stock (and not have to open the Google Voice app), right?
That's all I can think of for now. I'm sure I'll have more. You all seem like a very helpful bunch. I've also got a separate bluetooth issue that I'm really looking forward to being able to fix since the fix needs root. Thanks!
