Bean picker and color packs are now live...
Added a "No More beanpicker" basically takes all the pickers goodness away and a special beanpicker for BigBear!
Enjoy
didnt have any problems here adding a picture to a contact.... anyone else?
Just did a clean wipe and re-flashed 2.2.... After boot a female voice just whispered 'sourcery' (never heard that before) and scared the living hell out of me.... lol got to find out how to cut that feature off.
This may not be related to jbsourcery but is there a way to get the stuff like the Galaxy s 3 has like the voice command to answer and reject calls?
Once you've enabled the option in Settings -> JBSourcery Control Center -> Power Menu options. Setting is "Show navigation bar toggle"
When you long press the power button on your phone, you will see a row toward the bottom with a power symbol, home, back, and menu. The power symbol toggles the navbar. The other ones do what you would think. They act as a replacement for the now missing (if off) navbar buttons.
Sorry T-dev, maybe I'm drunk, but your response made no sense to me
Make sure all your alarms are turned off in Clock.![]()
I installed the add-ons, how do I access them?
Oh no, I want the alarms on, but I don't want a persistent icon in my status bar.Make sure all your alarms are turned off in Clock.![]()
If you're referring to the add-on pack, it downloads to /sdcard/sourcerytools/mods.
Flash the file.
