[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
Hey is it possible to request a lock-screen tweak where you pull the unlocker icon straight down to activate the Torch on your phone? I saw this in another ROM and thought it was EXTREMELY useful since I like to quickly use my flashlight without having to pull the bar down and activate the toggle =-/ Other than that this ROM is Effing perfect!
why don't you just make the bottom lockscreen target the torch?? :confused:
Hey all,
I didn't make the jump to 2.3.5 yet since we can't dirty and I just don't have the time to do all setting back up just yet, but I was wondering if 2.3.5 got rid of that weird bug I showed you guys where my personalized message at the bottom of the lock screen gets cut in half? Thanks as always.
Hey all,
We could not reproduce that so i would say its fixed as it never seemed to be a rom problem to begin with.
You can nandroid and try dirty install but please dont report any bugs do to ti please.
I'm still on 2.3...but with this new tablet look with the settings screen and home screen..Does it also force apps into tablet mode?
For tablet mode to work and look proper you also change dpi settings and that will effect the way apps appear as well. Some might look better and some may be off..
Mine would do the same thing. You may have to wait longer than ten minutes. I finally decided to start the download before I went to bed, and in the morning I was able to flash it.
After several more tries, finally finished loading apparently. But where are these apps? I could not find any. Looked to see if there were new flashable zips but found none. I even looked in my app drawer to see if they had installed themselves like play store downloads, but did not see anything new there, either. :confused:
copied from OP
Downloads from tools are now stored in sdcard/sourcerytool
I think I fixed the problem by changing a lock screen option. I no longer have it set to high and all is fine. As soon as I set it to high it goes back to it. Maybe it is a ROM problem. Maybe not.
OK, I know I've ruffled you guys feathers a bit with my one function request, I hope you don't hate me forever. And I really applaud the fact that you've got the derkernel as your kernel of choice. Trinity is my favorite as well.
But now I have a feature request. Your ROM has the WiFi signal text feature in it, but only as a -(dBm?). Could you also make/give an option to make it show it as a % as well? Or did I miss that the last time I was running 2.3?
TIA
Yea idk how to do the first 2 and I can't access my computer at work. And I've seen you do a lot more for other ppl in less than a day but yet every time I request something you ignore it but whatever
Then learn how to do it? Devs usually try and get major bug fixes out of the way before working on color coding
forget all this lockscreen stuff, how about a faster boot time cus my camera just clunked out on me and froze then said cant connect to camera and i had to reboot which took foreveeeerrrrrrrrrrr...well it seemed like it
edit- had to do a battery pull since 2 reboots didnt yield results...
2.3 btw
Not sure if this was mentioned but is the full screen browsing no longer an option in the 2.3? I can't find it in the browser settings I think it used to be under labs
I'm on JB Sourcery 2.3. Know this one's been asked before but I can't find the answer I'm looking for. Can I dirty flash 2.3.5? Do I have to flash the GAAPS again?
just want to clear this up.
If the answer your looking for is to not wipe on a full rom release by me it wont happen.
so if your looking for the answer of yeah dirty flash make sure to direct it to T-Dev because no matter how many times i tell him to stop telling people to dirty flash he wont so thats your best bet.
:) :) :):smokingsomb::smokingsomb::smokingsomb:
