[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
1) the system vibration settings are too strong. When I get a text while on a phone call I startle.
I respectfully disagree. This is probably my biggest gripe with the this phone. I have difficulty feeling it vibrate unless the phone is pressed up against my leg.
Have you tried the Trinity kernel? It has an option to change the vibration strength. Technically, I think it changes the frequency of vibration, but it seems to have the effect of changing the strength of the vibration too. Still not as strong as I'd like, but it's a lot better.
I saw the new version of the rom has a custom kernel by mofic of Trinity -- I wonder if it includes vibration control. Anyone checked yet?
just flashed 2.3.5. nice. thanks for it.
JMO, not liking the bamph paradime like dual windows in settings, gonna shut that back off and reboot. it's a little confusing lol.
running with trinity alpha 62 right now, was kinda choppy with trinity alpha 60
^^^^ Say it aint so! I absolutely hated that dual drop down crap from bamf paradigm. Although some people may like it, if its in future sorcery roms i would hope it comes with an option to disable it.
Pull your panties back in place, lol....
It is an option you can try or not... I dont like it either, but is an option for those who do:)
Mofic has just joined and this was mainly a beta to get it out and see. we are working on putting in custom kernel stuff we didnt do before because our kernel didnt support it.
SO much more coming on the front.
options. you like them you use them you dont you dont.
for everry feature someone hates someone else loves
so we make as much optional as possible.
The rom is set mainly so its pretty much stock unless you go turn things on.
Awesome!!!! To be honest I've never tried trinity...or any other rom for that matter...Been seeing great results on Franco. I tend to not try to fix what's not broken!!! If trinity is custom tuned or will be for this Rom..Awesome...means i won't have to flash a kernel!!!!!
Quick question (and bug?)...when I press the home key it doesn't do anything. It vibrates to acknowledge that it has been pressed, but it does not have any effect. I went into settings and changed the middle icon to a back button and that function just fine. I then changed it back to a home button and again it doesn't do anything other than acknowledge that its been pressed. Whats the deal?
Nvm - Forgot the gapps. Derp.
So can I get my request?
3 options for you.....
1. Take an existing icon pack and change the color to each image in photoshop yourself (guessing 100-200 images)....
2. Find the existing, if there is one, set from nbeebe24 and send to me....
3. wait patiently until I find it and put it in.
while we do try to turn things around quickly..... asking over and over for it , especially in the same day, can be quite annoying.
lol, glad you figured out the issue....
Yea idk how to do the first 2 and I can't access my computer at work. And I've seen you do a lot more for other ppl in less than a day but yet every time I request something you ignore it but whatever
