And I did find my own FB contact sync fix, so again, please forgive me.
what was the fix. tell us so we can tell others.
And the flashable file is called "Verizon_JRO03O-FacebookSync.zip" and I have placed a copy in my collection linked in my sig.Originally Posted by Instructions - Thanks craigacgomez
- Remove you Facebook account
- Go to Settings > Accounts & sync
- Uncheck "Sync Contacts" from every account (where available)
- Go to Settings > Apps > All, select "Contacts Storage" and click "Clear data) [you will lose any contacts which are not synced to any account]
- Reboot into recovery and flash the mod zip
- Reboot and enable "Sync Contacts" for all the account
- Add your Facebook account, select the contacts sync option and wait 2-5 mins
- If your Facebook contacts do not show up, go to Settings > Accounts & sync
- Select the Facebook account, and uncheck and re-check "Sync Contacts" and wait 2-5 mins (pictures may take a while to appear)
Since you mentioned it, I have to say, I really like(d) the quick message feature in Cyanogenmod, which allows the user to reply to SMS/MMS,without having to launch the messaging application. There are apps which produce the same pop-up functionality, but it's nice and incredibly functional, to be able to take advantage of the JB expanded notifications.
http://forum.xda-developers.com/showthread.php?t=1869521
Unfortunately, any attempt to install it as a system app on JBS, leads to a crash.![]()
is there a way to get an sms pop-up without having to download a third party app like handscent or something? simliar to what an iphone has when they receive a message.
would love a way to backup the settings so when we do clean flashes, our setup time will be faster
Gladly. I found it over at xda and it involves a change in ContactsProvider.apk. Apparently user craigacgomez made it, and there is a flashable file to backup and then replace the .apk, but there's some things that need to be done first.
Also, and I am speculating, that if you are doing a clean flash of this (or another JB) rom, you could flash in recovery; rom, gapps, and fix file, without having to do the steps above or maybe even be so adventurous as to just put the modified ContactsProvider.apk in the rom before flashing.
good luck
p.s. again I'm sorry if I got on your guys bad side, I'm not really that bad. Eagle, just ask listenman20 (ricky).
why would you be fixing permissions more than once?
Really more if a jelly bean issue,
Hey there, dear Devs, could you check something for me? I don't know if it's a ROM issue or a Jelly Bean issue...
Using the phone, I hit Google Now and the microphone comes right up, prompting me to say something.
BUT: Using a bluetooth headset, I hit the Google Now button and have to wait almost a minute while it's "initializing". Eventually it'll get to "speak now" but it's a whole lot faster just to type it all in. And that happens not the first time... but EVERY time.
Can someone on the team verify that this is an Android issue? And is there a workaround until Google fixes it?
Thanks!
Don't let my small stuff get in the way of your big stuff, Eagle. You guys are doing phenomenal work and I can live with a little BT nuisance for the quality of ROM you put out![]()
Loathe as I am to change ROMs, I will to test this - IF you want me to. But I suspect, greatly, that this is a JB issue and not ROM-related. If I were a betting fella, in fact, I'd lay money on it.
Let me know if you want me to nandroid JBSourcery, flash another ROM, test it, nandroid back and tell you the results.
