[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
I have a new problem that has just popped up. When I try to access Sorcery Tools I get a pop up that says "Sorcery Tools is for Sorcery ROMS Only" and the OK button closes it out. Worked fine up to tonight...any ideas?
It is the google wallet apk. it modifies buildprop and the toolbox thinks your on a different phone and thus gives the error your seeing
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=ICL53F
ro.build.display.id=JZO54K-4.1.2
ro.build.version.incremental=235179
ro.build.version.sdk=16
ro.build.version.codename=REL
ro.build.version.release=4.1.2
ro.build.date=Fri Nov 9 21:25:05 MST 2012
ro.build.date.utc=1352521505
ro.build.type=userdebug
ro.build.user=android-build
ro.build.host=Sourcery
ro.build.tags=release-keys
ro.product.model=Galaxy Nexus
ro.product.brand=google
ro.product.name=mysid
ro.product.device=toro
ro.product.board=tuna
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=Samsung
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=omap4
# ro.build.product is obsolete; use ro.product.device
ro.build.product=toro
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=mysid-user 4.1.1 JRO03O 424425 release-keys
ro.build.fingerprint=google/mysid/toro:4.1.1/JRO03O/424425:user/release-keys
ro.build.characteristics=nosdcard
ro.cm.device=toro
# end build properties
# system.prop for toro
rild.libpath=/vendor/lib/libsec-ril_lte.so
rild.libargs=-d /dev/ttys0
telephony.lteOnCdmaDevice=1
ro.config.svlte1x=true
# Ril sends only one RIL_UNSOL_CALL_RING, so set call_ring.multiple to false
ro.telephony.call_ring.multiple=0
# Turn on IMS by default
persist.radio.imsregrequired=1
persist.radio.imsallowmtsms=1
# Default ecclist
ro.ril.ecclist=112,911,#911,*911
# hardware info
ro.device.cpu=1.2GHz dual-core TI OMAP 4460
ro.device.gpu=PowerVR SGX SGX540
ro.device.rear_cam=5 MP
ro.device.front_cam=1.3 MP
ro.device.screen_res=720x1280
# ADDITIONAL_BUILD_PROPERTIES
keyguard.no_require_sim=true
ro.com.android.dateformat=MM-dd-yyyy
ro.carrier=unknown
ro.config.vc_call_vol_steps=7
ro.cdma.home.operator.numeric=310004
ro.cdma.home.operator.alpha=Verizon
ro.cdma.homesystem=64,65,76,77,78,79,80,81,82,83
ro.cdma.data_retry_config=default_randomization=2000,0,0,120000,180000,540000,960000
ro.cdma.otaspnumschema=SELC,1,80,99
wifi.interface=wlan0
media.aac_51_output_enabled=true
ro.opengles.version=131072
ro.sf.lcd_density=320
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=64m
dalvik.vm.heapsize=256m
ro.rommanager.developerid=icsourcery
persist.sys.camera-sound=1
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.android.wifi-watchlist=GoogleGuest
ro.error.receiver.system.apps=com.google.android.feedback
ro.setupwizard.enterprise_mode=1
ro.kernel.android.checkjni=0
windowsmgr.max_events_per_sec=240
wifi.supplicant_scan_interval=180
ro.config.ringtone=freebird.ogg
ro.config.notification_sound=Sourcery.ogg
ro.config.alarm_alert=Plutonium.ogg
ro.build.sourcery.version=3.2
ro.com.android.dataroaming=false
ro.goo.version=320
ro.goo.rom=JBSourcery
drm.service.enabled=true
ro.com.google.clientidbase=android-verizon
ro.com.google.locationfeatures=1
ro.setupwizard.mode=OPTIONAL
ro.gsm.data_retry_config=max_retries=infinite,default_randomization=2000,0,0,80000,125000,485000,905000
ro.gsm.2nd_data_retry_config=max_retries=infinite,default_randomization=2000,0,0,80000,125000,485000,905000
camera.flash_off=0
dalvik.vm.lockprof.threshold=500
ro.goo.developerid=TeamSourcery
ro.modversion=JBSourcery-V3.2
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.execution-mode=int:fast
ro.ril.enable.3g.prefix=1
ro.ril.hep=1
ro.ril.hsxpa=2
ro.ril.enable.dtm=1
ro.ril.gprsclass=12
ro.ril.hsdpa.category=8
ro.ril.enable.a53=1
Nope that didn't help. I extracted the Sourcery Tools apk and tried reinstalling it too, it installed, asked for SU rights then...same error. I'm not sure where to go from here?
I am just hoping - REALLY HOPING - that when the full 4.2 ROM drops that the old stock 4.1 deskclock will be available as a mod. I personally cannot STAND the 4.2 deskclock...
