kinfolk248
may be a dumb question but anyone know where i can find the changelog for 3.2, the latest one i see is 3.1.5..?
there's weather in the status bar now, missed that feature from the ics roms![]()
dirty flash rom and gappsEvening all, clean flashed 3.2, now i am stuck at repeating JBSourcery , it goes on for a few minutes and eventually the screen just goes dark. I have to do a battery pull to start and the process repeats. Any ideas?
Restoring Nandroid now, going to try and re-download 3.2 and try again.dirty flash rom and gapps
Turn on weather for the lockscreen and you will get an added bonus in the statusbarWeather in the status bar? Where is this mod of which you speak? I'm not finding it anywhere...
Thanks, I tried that, no luck. I am re downloading 3.2 now and will try again.should have just installed 3.2 right away... always a good chance the download was ok and just needed a fresh wipe
there you go.. you have a new home...
stay on that rom if it suits you
5000 downloads.. 1 person with lag...
and you will be on to something new 5 minutes after this post anyway...
That user had lag before his apps even installed.. kernel didnt work well on his phone. Now that he changed kernels it works perfectly for him.http://forum.xda-developers.com/showthread.php?t=1707358&page=124
Actually im at least the second to post about the lag
I posted about it becausei like your rom. Wouldn't have even mentioned it otherwise![]()
Sorry yours lags, but you have moved on...so everyone is happy.
