3.2!! Yes sir!! Thank you!!
WHOOT! Up & running on 3.2 with a clean flash and it is NICE. You guys knocked it out of the park again - and it's SO nice to have the 4.1 deskclock back on the phone instead of that hideous 4.2 clock!
Okay: I tried the new app/data TiBU zip method of backup & restore.
I do not like it, Sam I am.
First of all, flashing it takes awhile as Recovery extracts the apps into the app drawer. Then once you get to the home screen, the phone is practically useless* while TiBU restores the data. It takes just as long - if not LONGER - than the old way of doing things. And system data elements like SMS/MMS and call log will not restore via the method... so I had to do the TiBU restore for those anyway.
Long story short: a nice feature to have, but it's going to be another TiBU bell & whistle that I'll likely never use.
* - "Useless" meaning that you really can't use any apps yet, as the data is still being written to them. You CAN make calls and send texts. Remember that any texts or calls you send/receive will be overwritten with the SMS/MMS & call log backup.
Well done Team Sourcery - can't wait to see the changelog to see what's new![]()
How likely am I to dork something up if I uninstall apex launcher with Ti backup since I don't use it?
yes, make sure you have another launcher in place.... OR you be wiping and re-installing![]()
