[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
NBA League pass loads as usual. Except there is no dispaly once the selected game loads. The audio is fine and the menu/switch game overlay comes up as you tap the screen as normal, but the game is not displaying at all. The app has never done this before
Maybe the android gods are trying to tell you something about NBA basketball...
Got my phone back up and running smoothly again after a complete wipe. I have a quick question though. I need to encrypt my phone for work and since moving to Android 4.2, it will not encrypt the phone. When you attempt the encryption the phone just restarts and does nothing else. I wanted to know is this an android 4.2 problem or JBsourcery problem? Any help would be awesome.
Looks like there were some goodies added! Nav bar widgets and custom contacts in the quick settings menu just to name a few!!
I am wondering if I need to switch from cwm when 4.2 comes out. I am pretty comfortable with ROM manager but don't want to have issues or trying to move files and stuff.
Did they fix NBA League pass video playback?
And does this version require complete wipe?
Update:: it seems that NBA game time is not yet compatible with 4.2+
Running pre release #3 with lean kernel 5. Amazing work Sourcery!
Wallpapers: http://db.tt/LmvpAUKt
*from different sources
Will have to jump on RC3 soon!
Has anyone had clock FC on them? Had some issues yesterday, couldn't set an alarm.
I'm on RC1 now. May have missed it but is a full wipe recommended for updating to 3?
Speaking of clock, devs, I have a bit of an ish that I need help with:
I used Root Explorer to rename the (IMO despicable) 4.2 Deskclock "DeskClock.apk.bak" and copied the 4.1 DeskClock.apk into System/app. Rebooted the phone and went to add the 4.1 DeskClock to the homescreen in the spot that the 4.2 DeskClock USED to occupy, but which is now blank. I did this exact procedure with Pre-1 and Pre-2.
The DeskClock isn't in the app drawer! :eek:
I verified that DeskClock 4.1 is in System/app, and rebooted again. Still isn't there to select.
Any hints on why I'm not seeing this app? I NEED my clock. Thanks!
EDIT: Dread, a full wipe is NEEDED for 3, even if coming from 2 :o
EDIT EDIT: Nevermind, DUH. It was in the app drawer... under CLOCK, not DESKCLOCK. Amazing what happens when you look in the right spot, huh? :rolleyes:
