How do you get multiple widgets on the lock screen? Can't seem to get more than one
You can't swipe left or right from the lockcscreen? I think if you slide right it defaults to the camera, but you can slide left at least once or twice...
that option is to allow all the widgets to be accessible in the list. If you uncheck that option you only get the 3-4 widgets that are pre-installedOh yeah I can do that I just wanted to put two or three widgets on the same lock screen. There is an option in the tools to have as many as you want
make sure you are on the latest recovery and you are fine. BTW, nobody actually lost data... it was just in another folder that the older recoveries and the applications couldnt access, use of a file manager to move them to the correct location cleared up the issuesOK so I have download version 3 of the 4.2 but I am worried about installing it. I have seen everyone talking about these files messing up with /0 on them. If I use cwm and ROM manager and I going to mess up my phone and lose my music and photos? Thanks
but you still have data connection right?
did you install a theme?
Why do you like it? I tried it for a while and didn't see any benefit. I can speed dial my favorites a lot faster than using the toggle. What am I missing?Really like the contact toggles option! I haven't seen any issues with pre-release 3. Awesome work!
dirty flash rom and gapps... see if that helps
is your data turned on? do you have a data limit set?
