Can anyone help. Nandroids don't work. Flashing a 4.1.2 ROM doesn't either. Any ideas?
Mine is backwards. My old backups are in media/0. When I go into recovery they don't show up
Mine is fine in Charlotte. Probably vzw doing their thing
Actually the devs here gave it out. I can't do it right now as I'm on the phone but when I can I'll put it in the Dropbox and PM you the link, with instructions![]()
Sent from my Galaxy Nexus using Tapatalk 2
we're just talking about the 4.1 clock apk not the rom itself
Did you install the latest recovery ?
Okay I'm home. You are looking for the Deskclock4-1.apk file in the Dropbox here:
https://www.dropbox.com/sh/jezhl8v3mi778v6/14HiRICsh7
You will need Root Explorer or other... well, root explorer for this.
Put the apk file in the root of you internal memory (SDcard), then long-press and COPY.
Go up a level and scroll to SYSTEM.
Go into System/app.
There you will see the new Deskclock.apk and at this point, mount R/W (read write).
Long-press the existing Deskclock.apk and rename it Deskclock.apk.bak
Select PRESS and the copied Deskclock4-1.apk will be in the System/app folder.
Mount R/O (read only) and exit out.
Reboot the phone.
Enjoy![]()
click on the link in my signature
chief what did you do when going from 3.2 to the 4.2 rom?
just enter a nickname.. the pass phrase and your inSame log in as the forums?
