John_Roger
Should I be fine to dirty wipe? I did a clean install of 1.4 yesterday.
John, you can certainly TRY a dirty flash. But if things go south, be prepared and BACKED UP to the PC so you can do a full wipe if necessary. Folks are reporting a successful dirty flash coming from 2.4 and since it wipes /system anyway, my gut says you should be fine.
SHOULD.
John, I would make a TiBU backup first. If you're backing up Wallet, make SURE you either (a) reset data in the app and THEN wipe data in settings before you back up; or (b) make SURE you don't restore data when you restore it.
Then make a nandroid in CWM. Reboot, copy both TiBU and nandroids to the PC, as well as any recent pics, vids, or music not backed up yet.
Boot into CWM, wipe cache & Dalvik, then FORMAT system. Flash 2.4, and gapps 7-4 Proper.
Reboot and wait!
Then let's see what happens![]()
Btw 2.5 addresses deep sleep you might wanna try that.![]()
Nothing to be nervous about, just be cautious. Restoring Wallet data COULD fry that Secure Element and we can't have that. Just back up and flash. About to do it myself![]()
I've done nothing with wallet on this phone, so I think I'm ok. This may be my last flash for a bit. My GS3 arrives tomorrow![]()
SGS3 is nice, but you'll miss JB on it![]()
What is a mirror? Is that what you dirty flash?
I should have said "should be fixed" but glad to hear it's "better"Well, sort of. My Nexus wouldn't go into deep sleep until I walked outside so apparently it still needs a gps lock on. I've tried rebooting it both outside and inside and got the same results. Still, it's a lot better than having to manually do a gps lock after every reboot.
Noob doing my first dirty flash. Just want to make sure I got it right. Currently have 2.2 and proper gapps. Thinking about trying a kernel for first time to get improved performance.
- Wipe cache
- Flash 2.5
- Flash kernel lirano
- Reboot
And this process will not clear my current apps or settings?
- Wipe cache
- Flash 2.5
- Reboot
So I just flashed the newest 2.5 and now every time I restart the phone the first thing that pops up after unlocking says that UI has stopped. Any ideas on what might be causing this?
