Noticed one thing, the Carrier Text is broken again. Hardly a big deal, just surprising since it was fixed.
Mine says "Verizon Wireless". Huh.
And a random reboot while restoring apps+data in TiBu. This does not bode well.
Finishing the restore, but I'm not sure if 2.5 will last long...
...seems a little smoother than 2.2, but still not AOKP smooth.
If any version of JB is less smooth than any version of ICS, something's wrong with your JB install.
Hey Iwoloschin, if you have to do a full wipe, I would recommend Super Wipe. It doesn't just wipe the partitions, it FORMATS them. Does a great job at removing absolutely everything![]()
Dunno if I agree with this. Jb is nice and all but overall aokp b40 is way smoother than jb. At least on my phone.
I am having a devil of a time copying my TiBU backup to the PC. Only 4 things out of 238 want to copy over!
EDIT: Nevertheless, nandroid in progress...
I was having the exact same problem. I could see everything in my TB directory and could select and copy, but none of it would ever paste to my pc. Finally, just gave up. I have my nandroid backups and some older TB's on my pc for months past, so will just go with them if all craps out.
For some reason, I cant copy the new update onto my phone >.> i get an error saying its either stopped responding or has been disconnected, but any other file transfers just fine![]()
Believe it or not, I rebooted the phone and it copied over just fine!
Try above. Stuff happens in electronics
Are you transferring by USB?
I tried copying it over to my phone also, 2.5, and got an error. Something about the device isn't present or something. Then I ran the Md5 check and it failed. I downloaded the file from another source and it failed the MD5 check. So, I looked at the size of the files. On the sites I was downloading them from it shows 179 mb. The actually file size I showed on my pc once I downloaded them was 132 mb. Something isn't working right there
Trying my third download now, from a third link.
Update: No matter where I download it from, it gets to around 132 mb and stops downloading. After the 4th download of only getting 132 mb, I give up for tonight...just not working.
Has anybody restore a pre-JellyBean Nandroid since flashing a JB build? I've heard on Rootzwiki that it can cause some problems, just curious what all your experience has been? I don't think I'll want to stay on JakeDay's JB builds (or any other build/ROM) forever, and just making sure I won't have problems restoring old AOKP builds or flashing new ones in the future.
Yeah 4 times. Maybe 5 can't remember....
