andoird213
Android Expert
I remember the first time I did that and I thought I'd bricked it
Actually, after reading your comments (and a few others), I'm strongly considering TWRP, now.Thank you guys for letting everyone else know the problem, the solution and the REASON for the solution. You'd be amazed at how many lurkers are here, reading our stuff for nuggets of information yet never posting.
Hey lurkers: come on in, the water's fine and we won't bite!![]()
In all honesty, I'm having no issues with CWM Touch, as its served me since the OG Droid...but it sounds like a number of people are making the transition. If it's indeed faster than making backups via CWM, it's likely worth it.
The very bottom one, "Factory Images "mysid" for Galaxy Nexus "toro" (CDMA/LTE)", is the verizon stock 4.0.4 image. "maguro" is the GSM version. And there is no stock image on google for the sprint "toroplus" version.
When I had to flash all the way back to stock and start over, Wug's Toolkit did it all. You select what you want to do, it'll tell you when to connect your phone to the PC, and it runs the ADB/fastboot commands automatically for you.
The issue, though, is this: IF you flash all the way back to locked stock, it will take you clear back to 4.0.2 and you'll get an OTA notification. DON'T DOWNLOAD IT! Select "Upgrade Later" and continue the process of unlock, root, flash CWM, etc. THEN you can ROM, flash a nandroid backup, etc.
The flashable JB bootloader can be found here on the OP:
[ROM] Jelly Belly v2.6 - 07/09/2012 - [JellyBean] [4.1.1] [AOSP/Hybrid] - It's all about speed! - [VZW] Galaxy Nexus Development - RootzWiki
READ the first 3 posts thoroughly - if not the whole thread!
And check your MD5s!
Boy the interface on TWRP is pretty slick. Thanks guys. I'm slow to change and CWM is like an old friend, but this is all right.
http://androidforums.com/verizon-ga...d-jelly-belly-v2-6-7-10-a-21.html#post4644577Where does one get twrp? Heard a lit about it but so used to rom manager from koush.
Stock JB aosp is now up!![]()
Hello,
Should I wait until the AOKP ROM & Lean Kernel for the official Jellybean system is released or just start now and add later when AOKP/Lean Kernel is updated?
Which ROM are you referring to?
Both are made with vzw specific jelly bean. (Jelly Belly 2.6 (which I'm on) is built as a hybrid and works great, too).
Rootzboat
JB Rom Beta 1
Gotcha. It seems both are having bugs that I don't want right now though, but I'm very tempted to flash RootzBoat because Xoomdev will get it fixed in no time I'm sure. I don't follow the Rootz thread, so does anyone know of Jake posted an ETA on when his pure AOSP version will drop? Hopefully his bugs will already be squashed
jakeday said today sometime....that is all I have heard so far. I know he's feverishly working on it
Awesome. You know how much I hate wiping, and if I'm gonna do it, wanna make sure I'm flashing the most bug-free ROM (at the moment anyway)
