AntimonyER
CHANGED FROM AF ADDICT MIKESTONY
I think I am going to stick with 2.5 for a while. It's running so good right now.
Just curious, so did Wug's take care of everything for you? i.e. you just hook you Gnex up to your pc and could root and unlock it with Wug's? Didn't have to the it the old manual way using fastboot and all that (guess that is best way to describe it)
Which image is for the USA VZW GNex?
So this JB Bootloader: you just flash it in CWM / TWRP and let 'er rip? Does it wipe anything, or does it just reflash the fastboot img?
And then you reboot or something?
While we're talking TWRP, is that flashed the same way? In CWM? I'm sorry, Koush... I've used CWM for 2-1/2 years now, but I cannot STAND the sensitivity if this thing on the Nexus. Takes forever to select anything because I keep overshooting it!
Ok, so every time I've tried TWRP it hangs at the blue loading screen that says Team Win for about a minute and a half before the "shade" rolls up and I can get in to recovery. Does everyone experience this and just accept it or was it only me?
A few people have complained of that. Mine "hangs" for about 20 seconds or maybe less. Are you using "minute and a half" as a gut-estimate of what you perceive to be a long loading time, or have you actually timed it at 90 seconds?
Can someone please dumb down this JB boot loader thing? What is it, what does it do, how do I install it, and how do I get rid of it? Etc....
Thanks!!!!
It really is solid and not even source. Very content and to think it's only going to get better....however I'll be first in line to flash the first source based version from jake![]()
"I flashed TWRP as well as the latest nightly. Sheesh, I can't believe I've been tolerating CWM so long.
Frankly, I'm a little put out with Koush for not updating CWM for the Galaxy Nexus - and for the supposed "fix" being to purchase CWM Touch (I realize it's free if you want to manually load it). I already purchased the paid version of ROM manager, I bought both versions of the DX Bootstrapper, and I donated back when the DX was being hacked for the first time. I'm not spending another three bucks to fix a broken recovery.
So... Go TeamWin!"
Okay, ONE nerve-racking minute is over with!
I flashed the JB bootloader and all is well. Booted up just fine
I figure that, at this point, there's just no going back to ICS so what the heck...
can someone provide the links to TWRP?? we should update our recovery list
Boy oh boy did I just make a mistake I've never seen before. Since I have the JB Bootloader installed and I'm on 2.5, I figured I'd make a nandroid in anticipation of AOSP. So... I turned off my phone and instead of hitting both volumes and power, I hit volume down and power, like as if you're taking a screen shot. I have the big START arrow pointing to my power button and the little android. It says, "Downloading... Do not turn off target!!" I stopped right there. What the heck did I do????
