3devious
Android Expert
Hi Viperboy - Droid q for you. When my Droid is connected via bluetooth to my Ford SYNC, occasionally the bluetooth looses connection. When the connection is re-established the Music program (that came factory loaded on my droid) starts automatically. I have not found a way to keep this from happening using any of the settings functions in Music. I also have not found a way to delete the music app. Any ideas on how to keep the Music program from auto starting when connecting via bluetooth? I'd also take any help you can offer on how to keep my bluetooth from disconnecting from the SYNC system. Thanks!
I have a Ford Edge and my husband has the Droid. We can't even get it to connect via bluetooth because it times out on the Droid when we're trying to put the passkey in.
I've seen the problem you've had with it trying to go to the music player when you connect your phone via bluetooth. If you go into your phone settings on the panel that has your GPS, media, etc., check out the place where you've set up the bluetooth connection for your phone. I noticed a place in those menus that talk about playing music automatically from the bluetooth device. If you turn that option off, your phone should open its music player anymore.
I can't advise you about getting it to keep the connection as I haven't been able to make a connection with his Droid yet.
