ok, when I'm using AOSP or AOKP Roms, etc. Basically anything but stock Roms, others hear a static noise coming from my side when I talk via apps like, Teamspeak, or Skype. etc etc. Can I confirm that this happens to anyone else???
I couldn't get Skype to complete any calls at all when I tried it two days ago. I have the 0716 4.4.4 LiquidSmooth on my S3...
I found a new link for Liquid Smooth. They moved it to a different server and it's now up to build 3.2. I know a lot of people are going to be happy about this. The Liquid Smooth ROM d2lte link will now direct you to the new link.
With finding all of the unofficial builds, I'm thinking I should probably make a section in the list for the unofficial builds. Anybody think that'll be a good idea?
I installed this rom cm 11 nightlies on my virgin mobile SPH-L70 and the service provider changed from virgin mobile to sprint . what do i do
it works but the lte doesn'tIf you used the first APN settings fix I have posted, it has a Sprint PRL. So, it'll say Sprint as your service provider instead of Virgin Mobile. Your phone will still work just fine. If you flash the second APN settings fix, it will say Virgin Mobile. Is your phone working properly?
LTE doesn't work , what do i do
