Added two ROMs I haven't had on any of my lists: OSE and SOKP ROMs. Both are great ROMs with tons of features and customizations. Like AOSB, OSE also uses Sense Task Switcher. I'm currently using SOKP Milestone 3, which was released today. When OSE was an Android 4.4.2 ROM, I couldn't get it to work. But now that it's 4.4.4, I had no problems flashing and running it. SOKP has just as many, or more, features than Dirty Unicorns. I also flashed and used the newest AICP nightly. Bluetooth now works on it, so I deleted the unofficial 6/28 build I had.
I also cleaned up the links a bit. Enjoy.
Is the SOKP ROM buggy or more stable than AOKP????
I'm actually not too familiar with AOKP. But SOKP seems to be less buggy then AICP. I had overheating and lagging issues with AICP. I'm not having any of those issues so far. It's running smoothly, for the most part. This particularly build just came out yesterday. I am impressed with how many features there are. It's on par with AICP, Dirty Unicorns, and C-RoM.
Y
I'm impressed with SOKP so far. seems better. If only I had the option to disable data when screen is off
EDIT: Derp..... I found it!
Something I've noticed with this ROM is that the graphics seem to be clearer. I could be wrong. But the display seems to stand out. I also like that there are more options in the Quick Settings. I might be sticking with this ROM for a while.
One thing I liked about AICP that I haven't seen on any other ROM, is the option to open in floating window by swiping the notification to the left.
On other ROM you have to long press and then choose. The AICP way is way much faster and practical
I'm not positive--because I haven't used it--but I think LiquidSmooth has this feature...?
Currently using latest Liquidsmooth, just have to say that this ROM is awewome, feature packed:
Slim recents
Black UI
Control media volume
8 slider shortcut
Swipe left to open floating window
Hover
Theme manager
Int.d tweaks
Etc.
Best ROM for me so far
New LiquidSmooth 3.1 OFFICIAL jul/14 build
Index of /devs/teamliquid/Official/3.1/S3_Unified
I haven't notice any of that... Have you tried clean flash (I wipe everything but the external SD, then format system, then flash ROM)So, I just flashed this. Seems to run smoothly. But it seems there is a bug with some 4.4.4 ROMs. When I'm trying to download with from browser or other sources, it fails. I'm getting that quite a bit. It seems that it a bug within 4.4.4. The ROMs I've noticed this with are C-RoM, AICP, SOKP, and Liquid Smooth. Anybody else experiencing this?
Are you talking about the default browser???
Hmmmm so still on SOKP and my data usage seems ridiculously high. And I'm like 95% on WiFi. Only time I'm not is when I'm going home from school and back to school. Don't you think VM would've taken me of 4G by now????
New Dirty Unicorns unofficial TEST build by Sahil Munawar
https://www.dropbox.com/s/zd4dn979cnucjoi/du-d2lte-0713.zip
Geez, that's screwy. Are you usually rating those apps that much? Do you have the Data Usage thing to monitor Wi-Fi also? And yes, you probably should've been kicked off of 4G. But I've gone over 2.5 gigs before and wasn't slowed down. It's a good thing we have unlimited data.
Has anybody tried this out? I'm taking a little break from flashing ROMs.
