Ab5traktion
AOSB has made the jump to Android 4.4.4. I found a new link for Paranoid Android and going to check if the latest link is 4.4.4 also.
I'm still on DU when they first made their featuresHope it goes wellI'm still on DU when they first made their features
There's a new unofficial build of AICP with BT workingI do know it's working with Gummy. Other than that, not sure. I actually went back to using Dirty Unicorns. I'm waiting for either AICP or C-RoM to get Bluetooth working again to jump back to 4.4.4.
Sorry for the noob questions. I used to flash roms quite a bit before my EVO3D died. I've since gotten the SGS3 on VM. I've rooted it using odin3, knox_app_remover with the MK5_stock_deodexed rom and I have philz recovery. I recently decided to flash Liquid Smooth KK d2lte 6/18 nightly and really like the kitkat version. Data didn't work initially so I used Universal_vmu_ApnFix-v.R1 and I tested what works and what doesn't. So far phone calls, sms, mms using textra and data are good.
Here are my questions/issues:
1) I can't use the ##3282# to retrieve information from my phone like the EVO3D. Where do I find this info on my SGS3 phone like the mmsc and apn?
2) voicemail notification doesn't work and when I went to retrieve the voicemail by holding down 1, it connected me to a first timer using sprint mailbox. I'm on virgin so I'm guessing this may be the issue. This seems like it may be more of an issue with the APN fix I used than the ROM. Thoughts on what I should do?
https://www.dropbox.com/s/okwkpt1j3w2cwdk/aicp_d2lte_kitkat-5.0-UNOFFICIAL-20140628.zip
Haven't got the chance to tried it yet but one user commented on BT working perfectly
You might want to try a different APN settings fix. I have 2 of them posted in the OC. Both work. The mmsc is also posted. They're below all of the links to the 4.4.3/4.4.4 ROMs. The voicemail thing could be an APN settings fix issue. I think the one you used is an older version.
Phonesky is the play storeThank you for the reply. I did not install the modem since I'm pretty sure I have MK5 since my phone came with 4.3 loaded. The native voicemail worked fine after rooting.
I took awhile before flashing a custom rom. I just got annoyed by the bloatware and decided on Liquid Smooth. I have since loaded Gummy but the result is the same. I did a clean install with both roms. Neither would work after install so I tried both files from Universal_vmu_ApnFix-Custom and Universal_vmu_ApnFix-v.R1 from MopedRyder. I just tried flashing CM-AOSP_D2VMU_APN_LTE_or_3G-MMS_20131016 and it gave my stopped errors on boot.
I did flash 6-2_GApps_Minimal_4.4.3_signed. I noticed it has a file Phonesky.apk. Perhaps this is causing the issue. Think it is safe to remove the file and reflash everything?
Phonesky.apk is actually the apk for the Google Play Store. So, you probably don't want to delete it. You might be having a problem with the gapps package. 6-2 gapps are for Android 4.4.3 ROMs. 6-19 are for Android 4.4.4 ROMs. The latest Liquid Smooth and Gummy builds are for Android 4.4.4. So, use the 6-19 GAPPS package with those ROMs.
If the problem is still the APN settings fix, try the 2nd one I have on the OC. It's the newest APN fix.I posted both APN fixes in the case of one doesn't work, the other one might.
I don't know if you're using Philz Recovery or not. With Philz, after selecting Wipe Data, it gives you 2 options: first says Wipe Data, second says Install New ROM. Make sure you select the first option for Wipe Data. The second option does cause problems. I had a whole bunch of problems selecting the second option the first time I flashed a ROM using Philz.
I am using Philz and YES I did do the "Install New Rom" wipe. Good suggestion on the gApps also. I'll use the one you have listed. I'm going to retry it all using another rom and gApps and the R1 APN update.
I flashed 3.1 liquid smooth everything works, but the home button won't work. Could ths be software related?
Its assigned him,I tried activating the navigation screen and when I used that home button it did nothing
its working now, also is there a stock rom I can flash to if one rom fails?
I have a quick question well i updated my phone to 4.4.2 and my software version: L710VPUNDC and i was wondering if i could use these roms and i kinda don't want to BRICK my phone so if anyone can let me know please do you can reply here or send a PM so thanks
