10/15/2013: Napalm (R7)
- Fixed notification drawer layout
- Enabled water effect option on TouchWiz lock screen
- 360-degree screen rotation enabled
- Lock screen rotation enabled
- 1X Data-type indicator enabled
- Roboto fonts added
- AOSP style recents (no shortucts or buttons in recent apps screen)
- Holo themed contacts, dialer, in-call screen (like the camera, this is not AOSP styled)
- Minor UI theming tweaks
- APK Installation now shows in a dialog with Holo borderless buttons (instead of fullscreen)
- Replaced default sounds in framework with defaults from Evervolv (still working on the sounds made by the capacitive buttons)
- Switched default notification, alarm, and ringtone to match Evervolv's default
- Added Sound-About (Free Version) for notification audio routing to headphones (thanks to civicscootin)
- ZIP now uses Aroma installer
- Added AOSP stock live wallpapers and Sound Recorder
- Aroma installer: Option to remove Google Apps during install
- Aroma installer: Option to remove Facebook during install
- Aroma installer: Option to remove Wifi Tether, ES File Explorer, and Sound-About during install
- Aroma installer: Option to remove TouchWiz ringtones, notification tones, and alarms during install
- Aroma installer: Option to choose VaeVictus MG5 or Stock MG5 kernels
The fonts should be Robot by default but I have a hard time telling the difference. If it's not, please let me know and I'll include a flipfont package in the next release instead.
The system sounds have been set to match the ones from Evervolv (so no more water drop effect when you click an on-screen element) but I still haven't found the ones that are used when pressing a capacitive button (menu, home, back) so those still make the dreaded drip sound. I'll get it eventually, though.
A quick note about the 1X Data type indicator: by default, Samsung disabled the display of the 1x indicator for data connection. With this, if you live in a low-reception area, you may notice that it no longer shows 3G in places where it did previously. This is not an issue with the ROM lowering your reception, but rather, it is the ROM showing you what kind of connection you have REALLY always had in that area all along. The stock TouchWiz ROM masks 1x and shows the 3G indicator for every data connection that is not 4G. You'll still get the same reception, you are just better informed as to what kind of connection it really is.
I'm still new to Aroma, but eventually I'd like to make the installer a little more streamlined, for example, a single screen for all apps to include/remove with multiple check-boxes instead of several yes/no screens. I'll get it eventually.
I zipaligned all of my modified APKs this time. If anybody has any trouble with anything please, please get a logcat because there have been so many changes with this release that without knowing what package is causing the problem, I can't help you.
Conquest is now pretty much feature-complete. Just a few minor tweaks here and there, so the next release
probably won't be for a while. I do eventually want to get the dialer and contacts to look a little more AOSP-like, and I may try my hand at enabling the Ink effect on the TouchWiz lock screen (I really like the water effect).
Enjoy your cup of Napalm.
Quick update: SecMms.apk notifications are STILL not disabled by default. Ugh. I WILL get this fixed ASAP and push a quick update (hopefully with the water drop sound disabled as well).
Update 2: SecMms notifications DISABLED. Permanently. For sure this time. No kidding.
I also took the opportunity to remove SecMms's intent targets. This means when you choose to send a SMS or an MMS, it no longer shows up in the list of apps that you can use to send. This will only be for those of you who choose the 8sms option in the update installer. Please do not choose this option if you chose to use TouchWiz messaging in the R7 installer. Now on to that water-drop sound...
