civicscootin
Working well, just wish I could install victorious, and get Wi-Fi tether to work
Unchecking the "driver reload" seems to fix issue's..
Changing device to Galaxy S3 sometimes resolves issue's as well within tethering.
@Moon:
Link is still down bud
hope your surgery went well moon... Just reporting that I'm still having sms issues on 7.1a
I fully removed 8sms a while back & using GoSMS with no issues.
Great to hear all is pretty well Moon..
You've developed quite the little fan base here as well as other places around the net.
8sms installation is optional, however, if you choose not install 8sms, the stock TouchWiz messaging app will be installed/re-installed.
Agreed, I had (back in R6.x reverted 8sms to a user app so I was able to link it to Link2SD.
Just to gain slot space within internal. With that 8sms remained until I fully uninstalled it before the 7.1 update.
In short I have gone with the native Touchwiz (witch is great you gave us that option by the way) instead of 8sms as its one less icon to deal with let alone no future faults (if any) sense the native messaging app is still available (even though hidden ;-) *come.android.mms*)..
The theme is fantastic, mms is now working perfectly, blacklist is back, media sharing is available & wifi works great..
Sound.about for external notifications is sweet & ES file has always been my native ROOT browser, so top notch on the pre-installs.
Only 2 very very small issues I personally have is every now & then messages & data stops but a quick profile update fixes those issues (probably the main reason optimizer was installed to force profile updates every 30mins)..
& the other being the native video player does not open via icon, yet it playes from gallery :-\..
All in all what I'm seeing is maybe a few other 3rd party apps (Xsposed being 1 pre-installed) & a re-written kernel dedicated to this rom is all that's needed..
@Moon
Fantastic job bud..
It has been a pleasure testing for you.
~Civic
Link to r7.2 is down.
Btw aroma is the coolest thing i've ever seen.
