moonknightus
Links updated.
Dear ========, (Customer ID: -----------)
Recently we have noticed that your web site(s) is overloading the web server because it was using too many shared server resources (cpu/memory usage). Because of this, we have had to temporarily lock your account on the current server. We now request that you consider purchasing a Managed or other Dedicated Server in order to continue hosting with 1&1 Internet.
The decision to lock your account was made by the system administrators in order to improve the quality of service for the rest of our clients on the shared server from which you are hosted. The resource usage of your account threatened the ability of that server to capably operate as as a shared host , so it was required that your account be locked in
order to mitigate server load. Though we could unlock your site, it is not recommended.
Your account activity has demonstrated that your site deserves its own server to better suit its performance needs.
Please visit 1and1.com to review the server products we offer. You will have one (1) month to make a decision and migrate your account over to a 1&1 server or another host provider.
You can choose to return your account back to the previous state (unlocked), provided that you take steps to reduce resource usage of your account. If the account has to be locked again you will only have the option of purchasing a dedicated server account to continue hosting with 1&1 Internet.
Please reply to this email promptly. Further questions/comments should be directed to abuse-team@1and1.com.
Thank you for your compliance in this matter.
Sincerely,
Security Team
1&1 Internet, Inc.
As for video player, I think I'm going to remove the TouchWiz player and replace it with MX Player. I hate the TouchWiz video player but have been using MX Player for quite some time. If anybody has suggestions for a different/better player, though, let me know.
MX player is highly recommended..
Another good player I use is QQPlayer as the resources are far less the MX..
However with that said video quality is degraded do to pixelation.
I was also looking into the possibility of using VLC although it's beta, it has one of the highest media compatibilities of any media player. Going to test it out for a while. Maybe by the time I can sit down again, I'll have a decision.
Downloaded R7 full and in twrp 2.6 says cant open zip file. Downloaded it 3 times same every time.
2.6 TWRP is incompatible with many builds & is still rather beta.
Version 2.3.4.0 workes just fine & many users stick with that.
I like bsplayer also as it works for hd youtube.MX player is highly recommended..
Is it safe to wipe data for this rom? My phones being a bit wonky and thinking maybe it would clear up some issues. Just don't want to mess it up. I read though most of this thread didn't get a clear answer on it.
Thanks
Thanks
when i get to my computer tonight i will leech then seed
anything to help
I'm having problems with the lock screen weather and news ticker. On the lock screen it says "Unable to display weather data" and the news ticker is blank. When I go to Settings -> Lock screen -> Lock screen options -> Information ticker and tap Settings it lights up but never does anything. If I tap on Weather in the Lock screen options it then hangs for a sec and gives me a dialog box saying "Unfortunately, Settings has stopped."
When I flashed I did a factory reset then put 7 full and then 7.2 after. I also used VaeVictus. I haven't had any other issues besides this so far. Is this a bug or did I do something wrong? Any ideas on how I could fix it?
