moonknightus
10/20/2013: R7.3
- Fixed lockscreen news, stocks, weather, and Facebook tickers
Hey moon, you've been doing an awesome job with all Rom man. And I'm happy to hear everything went well with ur surgery. But I've been having trouble installing R7 Full and everytime I install it I just get stuck at the Samsung splash screen. I'm currently running pure stock odexed with vae_victus Mg5 RV3, not sure if this info helps, but I've been itching to use ur Rom, any advice to what I can do to get R7 up and running on my phone.
I think 7.3 borked screenshots. Just tried taking one and won't work.
Still isn't working. I wiped everything so maybe that's the issue, but I thought that it was required to wipe everything but the cards in order to do the full install.
since this is a closed source rom, i wont be using it.
A closed-source ROM using closed-source sources, legally, without GPL violations that I'm aware of.
On the other hand, you may have a partial point. Moonknight, if you want to avoid falling afoul of GPL, you may want to post any modified source code you've made to the open source components of the system. If all you changed was graphics, then I don't think you have anything to worry about.
Example: For my Nexus 10 ROM, I've posted links to the sources for all of my open source apps. Since I'm also using the closed-source Apex Launcher, I simply say I'm using it with permission.
I wasn't attempting criticism by any means, Moon, I was just citing examples. I know your work to be excellent and trustworthy, and I do enjoy watching you post updates, even if I don't use it myself. I have a lot of respect for you and your work.
I just felt like being thorough in my response to him.
Wiping system,data, cache, and dalvik is recommended. Wiping internal storage is not.
What recovery version are you using?
I'm using TWRP 2.6.3.0... never had any problems with it. I can normally troubleshoot my way through these kinds of issues with installations and whatnot. Once the weekend rolls around I will attempt this again, from fresh downloads, even though they appeared to be fine (the install process seemed to go off without a hitch).
Just to be thorough... I installed gapps, stock messaging, and tools from the installer.
