moonknightus
No I don't have power saving mode on, and what are the Xposed Framework and XTheme Engine??
See post above yours for XTheme Engine explanation.
See here for Xposed Framework.
Twrp
2.4.3
Q: What is Xposed Framework and/or XTheme Engine?
A: See here for an explanation of Xposed Framework and here for an explanation of XTheme Engine.
Q: I elected to install Xposed Framework and XTheme Engine during installation, why don't they work?
A: Due to the nature of Xposed Framework, these apps cannot be automatically activated during ROM installation.
To activate Xposed Framework:
1. Open the Xposed Installer from the app drawer.
2. Select Framework.
3. Select Install/Update.
4. Reboot your phone
To activate XTheme Engine:
1. Activate Xposed Framework if you haven't already.
2. Open Xposed Installer from the app drawer.
3. Select Modules.
4. Select XTheme Engine.
5. Reboot your phone.
Q: How do I apply XTheme Engine themes?
A: To apply XThemes:
2. Activate XTheme Engine if you haven't already.
3. Download and install the theme that you would like to use (they must be TouchWiz specific themes; there are some nice ones here).
4. Open XTheme Engine from the app drawer.
5. Select your desired theme from the drop-down menu.
6. Select Apply Theme.
7. Reboot your phone (do not soft reboot)
Was checking that out on their site... dosent look like this device is supported. Will try the zip.
Downloaded zip... Backup... Tried to flash from twrp, couldn't find zip anywhere. Verified the download in stock download viewer... added zip to Rom toolbox pro, booted to backup,install, wipe dalv-cache... got backup but zip didn't install.
Thus is first Rom I've tried on galaxy victory... Any suggestions: confused:
Tried hitting "donate". Its just a gif and not a link.
Got twrp 6.0, then Re downloaded the zip (checked file size14.3), says: "Conquest-plutonium-8.0.torrent" can see in sd ext download using total commander.
TWRP: still cannot see it in either download location. Can add to Rom toolbox pro's install Que but won't install into twrp?
Well try to subscribe to download instead of using guest link (mirror).
:screwy:
I have been using TWRP 2.4.3. since I first rooted the phone with great results. I installed Plutonium from 7.4 by just clearing cache and delvik and things went great, just an FYI. I guess YMMV.
Moon, just curious where you find time to go to the bathroom, I can hardly keep up with your updates and I am doing nothing more than installing them?
Great work!!!
wy a cant not install the new kernel get stock on samsung logo
U get bootloop on both kernels ? If so flash 8.1 then flash this
https://db.tt/gHaCS7Ya
See if that helps.
Oops my bad forgot 8.1 was just an update. The file I posted is ungoverned kernel to 1.5gig haven't seen a victory yet not run with it.
So it's like a fail-safe kernel?
I'd like to push it to my AFH account and link to it in the FAQs section of the OP if that's ok?
