FYI- It's not a great idea to restore system apps.Yes, running Victorious for two days now, but have had some issues.
What do you mean by copying them back over? I did try a restore from Titanium Backup which never did anything except keep trying and I had to kill it. What should the permissions be? They seem to match the other apps in the folder. And where can I find the deodexed versions? Is htere a repository of the deodexed apps somewhere.
Thanks for the advice regarding "/data/app safe to restore, /system/app do not restore". I'll remember that. Things seem to be going better with Victorious now, almost back to normal with the phone setup - though time will tell on the battery life/heat issue. So far, so good today though. Did you post a link to that new kernel yet? If so, do I just download and install from TWRP? Any other steps involved? Clear caches?
I also have a few more questions that occurred to me involving the external to internal sd switch that I would like to be very clear on:
1) As long as I'm running Victorious or updating it, I should never do any wipes other than perhaps caches, correct? Cache wipes and installs - nothing else?
2) Where should I put files I want to flash, like that kernel and the music zip? Still on the actual removable sd card which is now the "new" internal? Or should I put them on the original internal sd which is now the "new", smaller external sd?
I suspect as long as I'm not wiping anything other than caches, it probably doesn't really matter which I use? That makes sense to me, since some phones don't have removable cards and you can still root them and flash ROMs. I guess neither internal nor external sds get wiped when flashing ROMs, only /Device. Is that correct?
3) This is probably more important for me to understand correctly. If I ever want to reflash back to stock for whatever reason, or I want to flash an entirely new ROM, how do I deal with the sd swap? I am thinking I should copy EVERYTHING from BOTH cards and save to my computer before doing anything. I assume going back to stock removes the swap links and puts things back to normal with the small internal sd, and the 32GB removable reverts back to external. But what happens to the data on these cards? Does any of it get wiped during switching to something else? Or does it just end up being in the wrong place, potentially making a big mess to straighten out, depending on what all you have on them?
4) Where would I put the zip for a new ROM before flashing. The actual removable card, which is now internal - or on the original internal, which is now external? Or does it really matter?
5) Unless I am flashing directly to a new ROM that supports an ext4 partition, I assume I need to unlink all user apps from the sd card first, then reformat it back to ext2 or whatever is required by the new ROM?
Reboot and try again, if it still doesn't work, let us know which camera app you are using (the stock one of the one I added which is built for Android4.3), which version of Victorious you are on, and which if any version of VaeVictus kernel you have flashed.Camcorder stopped working
Strange, what governor and max/min clock speeds have you set, if any?Rebooted. Still says recording failed and closes. Both stock and the one you added. I am on most current victorious and kernal.
I got an update for SuperSu, so don't worry about that.Just checked storage and int 2 ext isn't working. Just noticed super su auto updated when my phone connected to WiFi. Think that could be my problem?
Strange, I let it update my binary by the normal mode, and it worked fine (not TWRP). Let us know how things go.I didnt do any links 2 sd at all. I only have a 4gb card right now so it would be kinda pointless. When supersu updated it opened in my pocket. (At work) when I looked at it was asking to update binaries so I did. That may have been the mistake. I just restored from my backup in recovery. Now im gonna flash victorious again.
