AndroidHaCks
I pulled a little over 12900 on antutu with the latest build
Where you on stock before you flashed, or a previous version of Victorious?I keep getting stuck at the Samsung screen after flashing the rom. I've tried multiple downloads and I've wiped the cache/devcache. what are some other issues it could be.
Sweet! Which governor?I pulled a little over 12900 on antutu with the latest build
What recovery are you using, CWM or TWRP?
Have you checked the MD5 of any of your download attempts just to be sure?
When you flashed the latest build, was the file 0.2.2 or 0.2.2-r1?OK, just flashed the latest build. I now have 2 Super Users. One has the Yellow Superman (called SuperSU) Shield with the Red Hashtag and the other has a blue square with a White Hashtag (called Superuser). I was not having the issues that others were so I never changed it after the last update. Neither have an uninstall option, so how do I uninstall it and which one do I uninstall?
Do you have an sdcard plugged in?okay ive gotten 0.1.4 to work but I cant get any of the 0.2.x to work they all have valid MD5 values. and I've tried every way to install them im just stumped on why I cant get it to work.
0.2.2-r1 should have removed the superman superuser app (ChainFire's), unless you had it linked to sd via Links2Sd (you should never have superuser moved from normal storage).
That output shows that the 2nd partition on your sdcard is not being mounted properly, now to see if the phone even recognizes it. Using terminal, type in the following
You are looking for mmcblk1p2, if it is not there, then the phone cannot recognize the partition. If you do not see mmcblk1p2, then there is a small chance there is something wrong with your phone or the software on the phone, but it is most likely an error with the partition. Try running fdsk with your ubuntu stick, and see if it can repair the partition.PHP:su ls /dev/block
So why was link2sd taken out? Also how do I oc gpu?
Links2Sd was not removed, the app was never included, you have to download it from the Play Store. What was included was my script that combines the extsd2intsd script with the links2sd script into a single script that does it all.So why was link2sd taken out? Also how do I oc gpu?
No, you will be fine. The only issues are those who have not followed the instructions to get things set up (the instructions are in the first and second posts of this thread).So if I flash the newest version over the previous version will all my links be screwed up? I have the partition on my SD card with link2sd installed and several apps linked currently, just don't really want to flash the new ROM if it's going to mess up my progress of freeing up all this space.
If you don't want to use Links2Sd on a 2nd partition, you should be fine. If you don't have a second partition, and you don't have Links2Sd installed, the script shouldn't cause you any issues.Is there a way to get it back to the way is just was before the update with all the other changes still working? Because I don't want to partition my card, and mainly because link2sd confuses the hell outta me.
