Your camera app may be confused as to where it is storing pictures due to the sdcard swap. Try setting your camera's storage to phone, then resetting it to sdcard, finally setting it back to phone so that it will store on your swapped external sdcard (which is actually phone, and phone is actually your sdcard in those settings).So I'm pretty new here but just wanted to let you know I rooted my phone and flashed this victorious rom and so far things are ok. I feel like my phone is running smoother and a little bit faster. Although sometimes when I press my camera button I will either get the stock camera or the other one. I noticed when I do take a pic with the stock camera they come out as a black screen shot. Also the wireless tether app always crashes.
Post number 2 gives config for wifi tether
I came across another issue... it seems under this rom I can't use adb to install and launch applications. Console says both launch install are successful but nothing on the phone changes and the app is not in the memory. Could this be issue with adb thinking the phone is running off of the internal memory still? Any workarounds to try?
If you follow the instructions and still have issues, let us know.
Have you installed any apps that have anything to do with sounds (media players, ringtone apps, notification apps, etc)? Have you gone through the settings to makes sure sound is turned on everywhere?I have a problem with my sound. It has all of a sudden just stopped working. I have been using victorious for a few weeks now and this is the first problem I've had with it, so I would also like to say thanks for everything.
Which version of the kernel are you running? There was a release or two where I forgot to edit default.prop, but the latest kernels (past two VaeVictus builds for sure), have the modifications. Are you able to do everything else via ADB? Also, have you tried a remount command on /system and /data before install/launch? And what OS are you running and on, Linux, Windows, Mac?I came across another issue... it seems under this rom I can't use adb to install and launch applications. Console says both launch install are successful but nothing on the phone changes and the app is not in the memory. Could this be issue with adb thinking the phone is running off of the internal memory still? Any workarounds to try?
I haven't modified any sound settings/files in the ROM, and we haven't modified any sound settings/files in the kernel
(as of ~10:00am est)Yeah, saw the commit, sweet sounding stuff!
BTW- we have an error in gpu-oc. Look at the first frequency line. At work note, well fix tonight if you don't first.
How long is the typical wait after flashing the Victorious ROM?
My flash seemed to go ok but the phone seems to just hang, over 30 minutes, on the Samsung logo after the Victorious Logo shows very quickly.
Well I'm backing up all of my apps right now throug titanium backup right now! I hope this works!! Thanks by the way!!
Warning- Be sure you download
Victorious-0.2.2-r1
or you will loose root!
If you have lost root, flash the superuser.zip
file in the downloads section.
Update 7-30-13
--Switched to Koush's Superuser
--VaeVictus-0.1.5 kernel (OC CPU+GPU)
CPU 384mhz-1.8ghz GPU 200mhz-400mhz
Be sure to thank rbheromax, the OC God!
--Fixed VideoPlayer playback
Thanks for the lib files TeachMe!
--Replaced bad bootanimation.zip
Safe to use bootanimation2
--Added VPN support (needs testing)
--Added native PlayStation Mobile
--Updater-script removes bad mount scripts
If you use scripts or apps that use scripts located in
/system/etc/init.d, other than Victorious's custom mount script, back them up before flashing!
--Inching closer to a .1 release
Note- See second post for details on preparing your sdcard for use with a 2nd partition!
A deodexed and optimized version of the
stock 4.1.2 (goghvmu) update for the
Galaxy Victory Virgin Mobile (rooted only).
Important - Victorious is currently being released as an update without the complete firmware package, which means you must be on the stock rooted firmware (rom), or Victorious, before flashing Victorious!
Do NOT wipe system or data partitions when flashing!
Update 7-24-13 : -Switched to VaeVictus overclocked kernel,
now you can overclock to 1.8ghz and use any of 10 different governors to control your cpu speed!
HUGE THANKS TO rbheromax FOR HELPING GET THE FREQEUNCY TABLES FIGURED OUT FOR OVERCLOCKING!
-Added support for zip format custom bootanimations,
use root explorer to rename /system/bin/bootanimation to bootanimation.bak and bootanimation2 to bootanimation, then reboot. I've included a sample Solar Flare bootanimation.zip in /system/media.
-Added some VPN services back in an attempt to get Video Player working properly again.
-Added the ability to use a 2nd partition on your sdcard with Links2sd for storage. You will have to partition your sdcard to ext4 (I used TWRP), remove all Links2SD links and the /system/etc/init.d/11links2sd script as well as the /system/etc/install-recovery.sh created by Links2SD if you have it installed already. Once booted, open Links2SD and if it asks to re-create mount scripts choose no.
Update 7-16-13 : Restored Activation, PRL updates, Profile updates,
Samsung Software updates, and Firmware updates.
Note- Activation may need to be done via phone pad by dialing ##72786#,
not sure if it works from the menus.
Restored ability to transfer files via NFC (needs testing)
Thanks to kwknott for finding the necessary apks and testing!Update 7-10-13 : Fixed WiFi Tethering, added Gallery/Camera4.3 combo (kept stock combo too), removed more bloatware and non-english fonts, changed Samsung boot logo to Victorious ROM!
Update 7-1-13 : Now has JupiterOne's RedSpot Uncapped kernel, and native extsd2internalsd support. Now your clockspeed is uncapped to 1.5ghz+, and app storage is based on your sdcard size!
Note- If you have the ext2int app or one like it installed (links2sd, etc),
uninstall the app and remove all scripts before flashing!
WARNING!!! Installing custom ROMs on your phone could brick it, rendering it non-functional, and voiding your warranty! I take no responsibility for what you do to your phone! You have been WARNED!!!
NOTE - You should turn your phone off before removing your SdCard! Unmounting in settings will unmount the internal SdCard since it is swapped with the extSdCard. Removing an SdCard while still mounted can damage the card's filesystem!
What's different about Victorious ROM compared to stock?
What's planned in the future?
- Rooted with Koush's open source Superuser
- Includes the VaeVictus overclocked kernel built from Samsung source with sauce added by rbheromax, overclock up to 1.8ghz!
- Deodexed (slower first boot, but faster from then on)
- Removed most bloatware (Samsung, Sprint, and Google apps, live wallpapers, extra fonts, etc)
- Better battery life
- Changed boot-logo (initlogo.rle) from Samsung to Victorious ROM
- Incudes VaeVictus kernel overclocked CPU to 1.8ghz and GPU to 400mhz!
- Changed bootanimations and shutdown animation, and added ability to disable bootanimations in the build.prop (set debug.sf.nobootanimation=0), as well as custom bootanimation.zips via bootanimation2 (see below)
- Changed boot and power off sounds
- Tweaks to the build.prop (taken from around the internet)
- Added support for swapping the internal and external sdcards for more storage
- Added support for using a 2nd partition on your sdcard for more app storage
- Added TrevE Mod Wireless WiFi Tether app (4G LTE Rocks!)
- Added GoogleGallery4.3 (combo gallery and camera, camera is cool but pics are so so, I left the stock camera and gallery in as well)
- Added native PlayStation Mobile
How to install Victorious ROM?
- Adding built in support for moving apps to sdcard Added in 7-1-13 update!
- Adding support for init.d scripts Added in 7-1-13 update!
- Adding support for custom bootanimations Added in 7-24 update!
- Add theme options (battery mods etc, try NinjaMorph for now)
- Attempting to add apps2extSd support, no promises Added in 7-24-13 update!
- More...
Download files and links:
- First, you must be running the rooted stock firmware and have TWRP or ClockworkMod recovery installed
- I highly recommend backing up your apps with Titanium Backup!
- If you have extSd2internalSd or links2sd installed, remove their scripts first!
- Download Victorious-0.2.2-r1.zip here, and place on your sdcard
- Boot into recovery by turning off your phone, then holding Volume-Up and Power at the same time till it starts booting
- I highly recommend you do a backup now, seriously!!!
- Wipe cache, then under advanced wipe dalvik-cache, DO NOT WIPE SYSTEM!
- Install zip from sdcard (you may have to choose external sdcard)
- Back at the main menu, Reboot System
- It takes a long time to boot the first time after flashing, be patient!
- Victorious-0.2.2-r1.zip (r1=root fixed) MD5 - 16d536820233b6a8b4fc73fa02801727
- Donate to Vmobi to offset hosting (I take no donations personally!!!)
- TWRP.2.4.3 recovery (Thanks TeamWin!)
- Rooting for newbies (thanks TheBritton!)
- Dsixda's Android Kitchen (thanks, made deodexing and zipalign a breeze!)
- Superuser.zip View attachment 58925 (Thanks Koush!)
Huge thanks to g60madman for creating Vmobi and hosting the files for Victorious, to rbhermomax for helping get overclocking working, to mattiadj for the extsd2internalsd script, kwknott for finding and testing apps to restore update functionality, TheBritton, Koush, TrevE for WiFi-Tether, and a whole lot more!
Ps. I flashed with TWRP. Worked just fine, so you might want to add that to the original post.
Mine has been stuck for over an hour and I'm still waiting I did make a back up so I'm not worried I'm just hoping it'll come through on me.how long did it take after u flashed and waited on the boot screen, it says it takes awhile the first time, but i was curious to about how long, and when do i realize when its stuck,,i dnt even kno what to do if it gets stuck...
Victorious-0.2.2-r1
Update 7-30-13
- More...
