zacharynasty
I also used mini tool to partition my sd, before I realized it wouldn't work, but I fixed my sd card now so its good, I just want to be able to fix this and and start again
11extsd2internalsd is my script, it's the only one you should see in /system/etc/init.d after doing a fresh install. My best quess is you had used some apps2sd app, and it installed something that is still affecting your. Before you uninstalled it, did you undo it's settings, and move apps back to internal?
FYI- You should be able to just remove 11extsd2internalsd and your phone will act like it has the stock sdcard setup.
Anyone having troubles with Victorious-0.2.2-r1 or 0.2.1, please try an older version, 0.1.x, I'm wondering if the bootanimation2 binary is causing the issues? If so, I'll remove it in the next release (I don't think it's being used by many, and it can be self-installed easily by those who want it).
Have you tried a different sdcard or repartitioning the existing one? I wonder if you might have a bad card or minipart may have messed the partitions up if it didn't work correctly
Make sure you are clearing the Dalvik Cache when flashing the ROM. Not sure it will help, but ya never know.
Try restoring this stock backup: http://g60madman.vmobi.us/goghvmu/stock/TWRP.zip
Follow these instructions to restore it: http://androidforums.com/5997674-post42.html
After you reboot from restoring, make sure you can make phone calls (if not activate), then under settings, do all the updates (PRL, Profile, Samsung software, Firmware).
Once the updates are complete, reboot one time.
After you have rebooted, try flashing Victorious-0.2.2-r1
Let us know if that helps!
As of now I'm having 2 problems. One, whenever I tap on the pencil icon in the new gallery app it freezes my phone. And two, I can't install new apps because it says I have "insufficient storage" but I've been installing my apps on my SD card and I have like 12 gigs available.
Ok I thought that since it says that the SD card is the internal memory it automatically installs apps to the SD. I downloaded it and it says that I can't move apps to the SD because the primary external storage is emulated
ok so i got it to work after i re flashed the rom, i wiped dalvic and cache again after it was successful, i only did it the first time before you flash... -__- hahahaha, thansk for all the imput you guys are awesomee
Glad to hear you got it working!
I removed the Samsung Keyboard, it was horrible.Thnk you , I ran into a few issues tho, my keyboard is totally gone, and when I do some operations on jrummies app and a cple other ones the screen goes black and the phone restarts, I haven't done anything to any files since I got it to work, any reason or way to fix this
Have you tried uninstalling, then re-installing those apps? They may have files stored on one of the sdcards, and now that the sdcards are swapped, they cannot find them.
If that's not the issue, try using TricksterMOD or Kernel Tuner to set your CPU speed lower. Work your way down till you find a stable speed for your phone, some can go higher than others. You don't get much performance benefit above 1.5-1.7ghz anyway.
Ok thanks dude, and I have mine set at 1.4 now and it seems to be running good, also with the internel swap with the sd cards is tht automatic when I download an app, for instance now tht my internal is 14gb with 3gb left, when I dwnload something does it go onto the the swapped sd card with the 3 gb left, or does it still go onto the other card, or do I need an app2sd to make it work
With int2ext only the file after the app goes on external card. Like some games have a large file to download after you install the app. The app itself still goes on internal card.
The part of your phone memory that apps are stored on isnt touched by the internal to external
