Yeah, I wiped the cache and dalvik cache. It just stays at the boot animation screen for more than 10 minutes. The only thing I can think of is to just start all over, but since I have over 300 apps on my phone It would take up a lot of my time just to update to the newest Victorious 0.2.2-r1 rom update.
I am currently on Victorious 0.1.4, I have ext2sd installed and link2sd installed. I also noticed after I tried to update to 0.2.2-r1 that I couldn't even update to 0.2.1 or any of the other newer VaeVictus Kernels after the VaeVictus-Governors update.
So, I can't even update my kernel on 0.1.4 to any of these at the moment:
VaeVictus-GPU-FastCharge
VaeVictus-0.2.1
I haven't tried any of the other kernels in between, but I may just do that to see where the rom breaks down at the boot animation screen.
These are the kernels I may try to test to see where it broke:
- VaeVictus-Overclocked
- VaeVictus-OC-Fixed
- VaeVictus-Freq-Fixed
- VaeVictus-Voltage-Fixed
- VaeVictus-OC-GPU
But, Yeah I am pretty sure the rom breaks down for those who are updating from 0.1.4 to 0.2.2-r1 and I think it breaks in the kernels most likely and not the boot animation. If not, It may be that I have to unlink all my link2sd apps and uninstall link2sd and or ext2sd.
Maybe if the stock or VaeVictus-Uncapped/VaeVictus-Governors kernel was temporarily put back into a 0.2.2-r2
I could then update my phone to the current Victorious rom, and then flash the newest kernel.
-FM
