Deck's 1.3, with the only caveat being that if you use the beta4 of dt a2sd, then I would choose the stable a2sd script because the beta4 script doesn't play very nicely with 2.3.7 roms. Deck's is like a trimmed down version of CM7 that is built specificially for the Evo, so there is more useless stuff taken out of the rom than what you would find on a build from the CM dev team.
With that said, everything on deck's works. Just flash the GPS fix found here and your GPS will lock as good or better than it does on Sense
http://db.tt/WZuFXULj
Here is the link for deck's. I assume you already know to flash the gapps
Download gingerbread evo deck zip
I am currently running xplod with tiamat 3.3.7 very nice and stable.
Does it get better battery life with the kernel it comes with or with a custom kernel? In your experience does it work better than CM7 (even tho it is CM7, lol)?
i was looking at that rom too...thought the camera didnt work...maybe a different rom..i'll check it out..thanks
so i just run the most recent gapps?
I just started playing with Decks and love it even the GPS worked with out the fix for me,
Tiamat 3.3.7. It's rock solid.Thanks MB. What kernel are you running with that?
You're about right....two points.I am newer to rooting. Please elaborate on
"Deck's 1.3, with the only caveat being that if you use the beta4 of dt a2sd, then I would choose the stable a2sd script because the beta4 script doesn't play very nicely with 2.3.7 roms"
I have my sd partitioned. Do I need to download anything else.
I would like to run decks so would the steps be.
System Wipe
Flash decks
Flash Gaps (are the gaps for all aosp roms the same, which is at the top of the roms down page under aosp???)
Flash GPS fix
Flash Tiamet
restart phone
THanks for any help!!!
oops thanx mizzou forgot to mention a2sd.Also you reference ICS builds, how do you know if its a ICS build. I am use to sense roms like mikg that do not need darktremor a2sd, is there somwewhere I can find steps to what to do?
